Finishing shop cabinets
  • gjat
    • 685
    • Valrico (Tampa), Florida.
    I haven’t posted in years but still visit regularly as all of you all are a wealth of information and experience…
    Im finally able to rework my 9x20 shop and want to replace my scrap lumber cabinets with the cheap HD wood cabinets.
    My question is what is the easiest quick finish for the wood cabinets so they don’t look like trash in six months from dirty hands? I’d prefer a wood finish instead of paint and don’t see the need for spending two months sanding for a fine finish. What successes have you had?
  • Slik Geek
    • Dec 2006
    • 708
    • Lake County, Illinois
    • Ryobi BT-3000
    For shop purposes, I often use shellac. The easiest way is to use Zinsser Bulls Eye Shellac - since you might be doing a number of cabinets, it may be better to mix your own. It is easy to apply, has less obnoxious fumes, stinks very briefly, and allows quick finishing (doesn't require days). Just be sure to understand the date code on the can to make sure what you are getting is not old. I have found that my coverage is much less than claimed on the can, so don't skimp on the quantity. See Stumpy Nubs Youtube video on using shellac. His application technique (cotton cloth wrapping cotton balls) is good advice. Shellac isn't as durable as polyurethane, but is much quicker to apply.
      • 3110
      I have to concur with Slik Geek on the shellac. It is very easy to apply and with the exception of lacquer, the easiest to make repairs to if you do damage the finish in the future. Polyurethane is much tougher, but if you damage it, you are pretty much sanding it all off and starting over.
      • gjat
        • 685
        Thanks for the advice. I feel comfortable to go with the shellac. I’m not looking to make my shop cabinets into fine furniture, just better than the scrap wood storage I’ve lived with for 20 years. Two coats should be enough to limit greasy finger stains without making this stage into a months long project.
        I’m re-doing my shop now that I have the money and plan to retire in a few years. After the base cabinets, I’ll modify the electrical, paint or stain the concrete floor, possibly do something with the dust collection, build or buy an actual woodworking bench, and hopefully enjoy woodworking and tinkering instead of always making do in a makeshift shop.
          • 3752
          For shop cabinets i prefer the look of painted cabinets. It brightens up the shop. As far as dirty finger prints, paint cleans up well, and if it is a messy spot that won’t clean you can always smear on another cover up coat on that spot.
          • jacobs
            • Apr 2024
            • 18
            For your wood cabinets, consider a quick wipe-on polyurethane for durability without extensive sanding. As for shopping, Wayfair Canada offers a wide range of affordable furniture and home improvement products, so check ratings before buying.
            • Slik Geek
              • Dec 2006
              • 708
              • Ryobi BT-3000
              Two other things I really like about shellac:
              I have a basement shop. When I finish with shellac, I open a window or two for ventilation, then apply the finish. After I clean up the stuff, I close the window(s) because the finish dries so quickly that the fumes stop within minutes. The big advantage? I've finished several times with shellac and the wife has no idea. With other finishes, the smell lingers for hours and the wife complains about the entire house smelling. One cabinet took months before my wife stopped complaining about the smell.
              Want to do a second coat? You only have to wait minutes and apply the next coat of shellac. I love the speed of application and how quickly I can add the second coat. Finishing is fast and is always done in a short evening of work. Finishing is enjoyable for me with shellac.
