Shop is one step closer
  • Filter
  • #16
    Dedpedal, understood on wanting to increase shop size. How are you planning on doing that? Expand the existing structure - or build/move to a new structure?
    http://www.elksigndesigns.com
    • Dedpedal
      Dedpedal commented
      I’m in the small corner of a three car garage for now. We got a bid to add on for 70k. That’s a bit out of our budget so I’m trying to convince my wife that her car can stay outside so I can have more area to work.
    • Stan
      Stan commented
      Yikes, that is almost twice the cost of my shop.
  • #17
    Well, we were one step closer.... Electric co-op informed me today they are having supply issues with transformers, and apparently the box I need to have power pulled from needs an upgraded transformer.
    So now it appears I am at least 2 months out to get power.
    • #18
      Looks like something is going to have to be done with the lean-to exterior walls to keep snow from coming off the roof and into the lean-to.
      Click image for larger version  Name:	Shop Lean-To Snow buildup.jpg Views:	0 Size:	244.8 KB ID:	853236
        capncarl commented
        If you run the sheet metal to the ground it will probably not be strong enough and bend inward. I enclosed a portion of my shed with pine fence planks matching my neighbors and my own fence. It probably has the strength to withstand snow side load.
      • Stan
        Stan commented
        Sheet metal it is.
