I am wiring my 9 X 12 workshop _from_ the 200V circuit for the oven/stove circuit in our house and am having a little bit of trouble understanding this Japanese system.
Setup:
Under the house (good spacious concrete crawl space) where the wire goes to the (would be) electric stove, I cut the wires and connected it (screw type clamp for electric wires) to a set going to the shop. The wire to the stove, and from there to the shop, are 2.6mm. Total run from main house circuit breaker to shop is about 50 feet. The wire from house to shop (8 feet distance) is in water proof conduit under ground.
Most Japanese 200 Volt house systems have 2 hot wires and NO Neutral wire for 200V AC or etc.. There is/was a ground wire going into the wall to the outlet for the stove. (BTW we are not using an electric stove, so the circuit is not in use.)
Shop setup:
I have a small 4 switch (20 amp each) circuit breaker in the shop. I brought the 200 volts in and set two circuit breakers to be 2 separate 100 volt lines (opposite sides of the 200 volt main switch). The two other switches are also set up this way, but are sent out as one 200V line for a very small 200V welder.)
My Problem: With two hot wires and no neutral wire, the 200 Volt welder works. But when turning on ANYthing on either of the 100 volt sides will trip the _House_ Main circuit breaker.
I brought the "ground" green wire (ran from the stove ground wire) in with the 200V. This ground wire was added to the "neutral" of the shop circuit breaker. I found out that this is a no-no inspite of two Japanese electrician's advice to do that. This was the problem that caused the main circuit breaker to trip when turning on anything.
The Main house circuit breaker does have a "Neutral" side and all 100V runs have this "neutral" wire. I found a 100 V wire (2.0mm) under the house with a neutral wire and "spliced" into it (neutral/white), then ran it in a conduit to the shop and hooked it up to the Neutral of the shop's circuit breaker.
Now, the 100V sides work fine. The 200V circuit works for the welder, but it does not use the neutral wire.
The PUZZLING part: Wanting to be safe and do like the house was set up with the 200V stove, I hooked the ground wire onto what looked like the "ground" screw of the shop circuit breaker. Now, the problem of tripping the main circuit breaker started again when turning anything on. I took the gound wire off and the problem went away. The circuit breaker did not trip upon hooking something up (which would indicate a short) but when turning it on.
With the neutral (white) wire by itself, everything works fine (so far) on the 100 Volt side, and 200V side.
200V welder work fine with 200v with the plug's green wire attached to a "grounded" outlet - but without a neutral wire at all.
100V will not work with green ground wire in lieu of neutral.
I wish they would put neutral wires in all of their 200V systems! A pain.
I don't understand this system over here! Thanks for letting me rant!
A bit of humor: over here, the ground is called "earth" and pronounce "assu".
Setup:
Shop setup:
