Many books I've read on finishing talk about wet sanding, but none so far has really described the process. The liquid used has to match the finish, I gather (ie, water for water bourne finishes, etc), but how much?
Do you flood the surface then sand? Wet the paper then sand? Is there a difference in technique for water bourne vs. others?
Help!!!
And thanks!
Help!!!
And thanks!
