So far this week I cut the sides, top, and bottom to final width. I traced my
pattern on the sides and cut them oversize with a jigsaw. Working on one
side at a time, I clamped the template to it and then used a flush trim bit in
my router to shape the side to final size. Point of no return stuff here. Scary
stuff.
This morning I had to go buy a Bosch 3/8" roundover bit at Lowes. I didn't
have one that size. What a difference a sharp bit makes! More point of no
return stuff.
I decided to roundover as much stuff before assembly as possible. I started
on the inside face. When I came to a dado, I stopped short.
The roundovers REALLY set off the piece. I like it!
Before I can really go one, I need to patch this spot on the inside face of one
of the sides. I had to include this bit of bark to get a wide enough glue-up.
I masked the area with painter's tape first. I really should have masked more.
I've got plenty of fine wood dust so I mixed it up with some 5 minute epoxy
and scooped it into that gap.
Hopefully in the morning that epoxy will be rock hard throughout and I can
continue. I took the day off work tomorrow so I think after I finish cleaning
up the epoxy, I can do a final dry fit, cut a rabbet in the back pieces for the
back, do a final sanding of the interior parts, and maybe even do a glue-up.
I hope I can get to sleep with all the expectations.
Paul
stuff.
return stuff.
Paul
