Note to self: Remember to wipe the mouth of the can of poly before putting the lid back on. Otherwise, you'll ruin the lid when you have to pry it loose.
So now I have almost a full can of brush-on poly that's the consistency of taffy. I thinned it with mineral spirits and used some in a very thickened state to protect new wheelbarrow handles. I'd be OK using it on shop cabinets, but I'm not sure whether I'm creating more problems than I'd solve by continuing to use it for projects that don't require perfection instead of simply throwing it away.
It's my fault. I dip my brush directly into the can in order to avoid the waste and cleanup hassles that go with pouring small amounts into a smaller container for an individual project. Residual ploy on the mouth of the can sealed up tight and after prying the lid loose a few times, it no longer forms an air tight seal so the solvent has largely evaporated.
Would it be better to just wipe this stuff on instead of using a brush?
