This is my obsession for today.
Anyone ever built or thought about building a trebuchet?
BT3 FAQ - https://www.sawdustzone.org/forum/di...sked-questionsTags: None -
I've wanted to for a LLLLLLOOOOOOOOOOOONNNNNNNNNNNGGGGGGGGGG time. I don't think my problem/renter neighbors would like it thought. (aka the target)She couldn't tell the difference between the escape pod, and the bathroom. We had to go back for her.........................Twice. -
I came in just to see what is a trebuchet, and had to google :
plans : http://gottatopic.com/blueprint-for-a-trebuchet/
A socio-logistic question : at what point of the construction do you think you will be interrupted by your neighborhood watch, or have a cease-and-desist served on you
? (after all, once you finish, somebody's gonna suffer)
- AristotleComment
I just checked and the game is still running here is the link. http://www.globalspec.com/trebuchet/ I have played it some.Comment
"Anyone ever built or thought about building a trebuchet? "
Only every day. I would make one taller than my house so I can "defend" my land (aka small subdivision parcel) from all points of attack. I also will use a french accent to ward off would-be attackers.Comment
http://richardspensandthings.blogspot.com/Comment
I built one for the sole purpose of launching rolls of toilet paper up a few hundred feet from the back of a pickup truck. Unfortunately before it could be used someone got our neighbors instead of us, and then they banned toilet papering.
If you do build one, I'd suggest one that has a fulcrum that can move forwards and backwards so that your counter weight can fall in a straight line. It is a much more efficient design.AlexComment
I never thought of building a mini one, but someone mentioned toilet paper rolls...looks like I have a new project in the que
I have thought of building one, but have talked myself out of it many times.
Maybe a scale version will satisfy your obsession for now??? Or maybe make it worse.
Here is an example:
http://www.instructables.com/id/Wood...top-Trebuchet/If you can read this you assembled wrong.
AlanComment
i'm thinking about one sized to hurl tennis balls 50-100 yards.
Playing tennis 3 times a week gives me an almost inexhaustable supply of balls and there's a neighborhood park nearby to use, tennis balls will be a lot less lethal than golf balls.
Where can I get some barbell plate weights cheap? I need probably 2.5 5 10 15 and 20 pound weights to be able to vary my CW force. They're kind of expensive thru Amazon or whatever and shipping will kill you.
The size would be on the order of 30 inches high axle. You could hide building one like that without alarming the neighbors.
There's free progams on-line to model the characteristics (5 lengths and three weights) to show you how it might perform.Last edited by LCHIEN; 05-23-2009, 11:18 AM.
You could probably find some used ones at a second hand store such as Goodwill, Savers, Salvation Army, etc.
I wonder if anyone sells Trebuchet insurance?If you can read this you assembled wrong.
AlanComment
Footer Ad
LCHIEN
