Sort of a general question. My garage door, a double size door, has three hinges that have pulled out due to the bolt threads stripping the MDF. I have three new hinge/rollers that I want to install, but wonder what the best method would be.
One option is to simply use larger diameter bolts.
Other option is to fill holes with putty or wood plug, or some sort of epoxy filler and then using the existing bolts.
Anyone have any suggestions on how to best attach these garage door hinges to a MDF garage door?
