1/2# cut bulls eye shellac?
  • newood2
    • 600
    • Brooklyn, NY.
    Zinsser Bulls Eye dewaxed shellac that comes in the quart is a 2# cut.
    How much denatured alcohol do I add to make it a 1/2# cut?
    Howie
  • jziegler
    • 1149
    • Salem, NJ, USA.
    The cut is how much is disolved in a gallon of alcohol. so 2lb cut is 2 lbs in a gallon. You need 1/2 lb in a gallon. So it should be 3 parts alcohol to 1 part shellac.
    Edit:
    I was a little too quick and too simplistic. the right answer is 2:1 alcohol to shellac. The explaination is in the article below.
    http://www.taunton.com/finewoodworki....aspx?id=28833
    • newood2
      • 600
      • Brooklyn, NY.
      Thanks Jim
