I didn't see a finished ellipse making jig so I'm posting the one I just finished.
I'm making a bent lamination that needs half of an ellipse as the form. My
attempts at using a fair sticking and nails were less than fair. I had trouble
cutting the shape and then sanding a fair edge. I wish I had an edge belt
sander.
Anyway, I looked closely at the Rockler jig and pretty much copied it.
http://images.rockler.com/tech/RTD10000285AA.pdf
The "keys" are 2" lengths of Rockler T-track. They slide in dado grooves that
are cut perpendicular to each other in some plywood. The keys are screwed
to the trammel so they can still freely spin but there is no side to to side
slop. To properly size your jig, you need to know how big your ellipse will be.
The length of the groove measured from the center to the edge must be at
least 1/2 the length of the difference between the major and minor axis.
In this picture you can see the base screwed to my future form and the
trammel laid on edge.
A shot of the jig on the base after cutting close to the line and before cutting
the final ellipse. Hand pressure at the center of the trammel keeps everything
happy.
Paul
sander.
happy.
Paul
