Announcement
No announcement yet.
Cutting wooden balls in half?
  • Filter
  • Cutting wooden balls in half?
    What's the best way to do it? There's gotta be a (safe) way.
  • #2
    Need to know a few details.
    What is the wood?
    What is the diameter?
    What is the project?
    • #3
      how big and do you care if you mark the outside, at all, a lot or a little?
      • #4
        Hi Ed
        I found some jig for a band saw but maybe it will work also for table saw.
        Please have a look http://community.woodmagazine.com/dg...yCurrentPage=0
        Regards
        niki
        • #5
          I made something some time ago very similar to the one Niki posted above. It was a one-time thing, so I used the parts on other projects, but it worked very well. Used a 3" hole saw for the holding indents, and a standard door hinge to hold one end of the two pieces together, then ran it on the bandsaw.
          • #6
            If you have a band-saw, I'd fab up a splitter so you can guide the ball through the blade. It's not the spinning as much as twisting or cutting straight. I WOULD NOT try it on a table saw. I've used a splitter to cut dowels that uses that principle. I'm sure it would cut spheres just as easy.
            • #7
              first you get uma thurman aka Black mamba. Then you give her a Hattori Hanzo sword. then you throw the balls at her.
              To understand this you have to have seen Kill Bill I and the scene with the Baseball.
              • #8
                Originally posted by LCHIEN View Post
                first you get umma thurmon aka Black mamba. Then you give her a Hattori Hanzo sword. then you throw the balls at her.
                I have cut a baseball in half with a katana. Not a thrown one, mind you, but on a tee. Amazing how much material is contained in those windings. I sure wouldn't try it with a solid wooden ball, though.
                • #9
                  LOL can she resaw some panels I have the same way?
                  • #10
                    What is the wood?
                    I don't have a project. I don't even have a ball. Just happened to think about how I would cut the ball if I had to.
                    The link Niki posted looks promising. Now I just might have to try it in case anyone asks me how to do it.
                    • #11
                      unless of course, you were weilding an H. Hanzo blade.
                      • #12
                        talk of chicken and egg...
                        reminds me of an oriental wise-crack : like somebody roaming around with a key in hand, searching for a lock it could open
                        - Aristotle
                        • #13
                          Even the best blade cannot entirely overcome marginal skills such as mine, despite many years or training.
                          • #14
                            how bout you use on of those 45 degree miter sleds and turn it around so the ball is nested in the square then hold it down with a board with a hole in it like earlier
                            like thisClick image for larger version
                            Phil In Ohio
                            The basement woodworker
                            • #15
                              Man, that starts my day off with a laugh. Click here to join me.
