Hello,
I am building my first project, it's a small entertainment center to go under a lcd tv. It is being made mainly out of popular plywood. Anyway I am trying to get a dark ebony finish, I have done alot of research on here and have begun testing some different techniques. So far I tried minwax ebony stain, on raw wood, which only made the wood a light gray. Next I tried another test piece with some of the homestead black dye mixed with water also on raw wood after I raised the grain and lightly sanded. This came out much darker. Next I tried another piece with a little more dye added to the mixture and it came out even darker. However when when it dried I could see some of the wood color coming through. Should I next put a coat of the ebony stain over the dyed piece to cover up the spots that are bleeding through. Then follow that up with some coats of wipe on poly. I want to be able to see the grain patterns still, but right now I can see the actual original wood color in some areas.
From what I read that is what it seems like you guys are doing. Should I do any light sanding ant any stage or just in between the clear coats? Any suggestions from the experts would be appreciated, I know for my first large project a choose a tough color! I saw a couple members’ projects on here with the dark ebony look, I can't remember who, but that is the look I am shooting for.
Thanks in advance,
From what I read that is what it seems like you guys are doing. Should I do any light sanding ant any stage or just in between the clear coats? Any suggestions from the experts would be appreciated, I know for my first large project a choose a tough color! I saw a couple members’ projects on here with the dark ebony look, I can't remember who, but that is the look I am shooting for.Thanks in advance,
