OK, I got a new one carved out as best this amateur can do. I did not have any really hard woods but I did have a piece of what looks like mahogony. If it breaks I'll get a better chunk of wood and do another one. Actually I dropped it on the cement floor twice and it didn't break so maybe it will hold up.
What I need to do now is drill that hole through the center. Anyone know of a good way to do this? I don't have a drill press but I do have the use of one.
I was thinking of notching a block of wood that would be the correct angle between the hole and the handle base. I'd set this up using a long bit in the drill press that would extend through the old handle, without running the drill press of course. Then once the correct angle is set, put in the correct bit and drill the new handle.
How's that sound?
How's that sound?
