Removing cabinet hinges
  • kmk
    • 415
    • .Portland, Oregon
    We have the following door hinge in our new cabinets. How do I remove the doors? Trying to join faceframes together..
    Rockler calls these as Blum 2-Way Nickel-Plated Face Frame Hinges.
    Any ideas?
  • kmk
    • 415
    • .Portland, Oregon
    without removing the screws I meant.. Possible to just detach it?
    • RayintheUK
      • 1792
      The door part connects to the face frame part with the metal arm. The screw that would be covered by the door part when closed should be the one to detach the arm from the frame mount. Try this on the bottom hinge first.
      Ray.
      Did I offend you? Click here.
      • kmk
        • 415
        • .Portland, Oregon
        Thanks Ray. I did have to remove a screw... I was hoping I can just snap and detach the door. ...
