Cleaning Flagstone
  • Greg in Maryland
    • 250
    Cleaning Flagstone
    Hi
    I need to clean the hearthstone in front of my fireplace. I put a potted plant on it last winter and it left stains on the stone. In addition, I have what looks like rust stains on the stone.
    I believe that the stone is flagstone or blue stone. The stone is similar to this: http://www.irwinstone.com/PhotoGalle...20Blue_jpg.jpg
    I have tried soap and water with a sponge/scrub pad, but it didn't do a thing. I was thinking of using TSP (Tri-Sodium Phosphate) with a bristle brush. Does anyone see any downside to TSP on stone? Any better alternatives?
    I am aware of the caustic nature of TSP and the need for safety precautions, so that isn't a big issue.
    Thanks.
    Greg
  • LYU370
    • Mar 2005
    • 215
    • Streamwood, IL.
    Here's a site with a bunch of good info, a lot of it refers to their products, but it sounds like you can use a grout cleaner to get rid of the stains.
    http://www.aldonchem.com/section-answerbook.htm
    Andy
    • christiandad
      Handtools only
      • Sep 2022
      • 1
      My go to man when in need of inspiration and tips is Devin, I highly recommend you check some tips here. Hope it helps!
      https://www.devineescapes.com/diy-flagstone-help/
        • 3791
        I would fear that anything you put on the stone to remove rust will leave a light spot causing you to have to put it pop they whole fireplace.
        • anglinastone
          • Sep 2022
          • 7
          • United States
          In my opinion, Cover your flagstone patio with white vinegar. Allow the vinegar to sit on the flagstones for a couple of minutes. Rinse the vinegar from your flagstone patio. Use your scrub brush to clean your flagstone patio​
