Need gas pressure drop calculations
    After doing more research on my future tankless hot water heater, I've landed a couple more questions.
    A plumber I've used in the past offers units from Rinnai. He has never actually sold one, but is interested in getting one under his belt and seems very helpful.
    A possible concern a couple of people have mentioned is total BTU's drawn. I have a 250,000 BTU meter, the Rinnai pulls up to 180,000, and I think my furnace is up to 120,000 BTU's (I have to check). So the first question was, will my meter accomodate that. I called our local utility and spoke with a very helpful tech who told me (1) The meter is capable of 300,000 to 325,000 BTU's. (2) If I did exceed the meter's supply, I can get a larger meter installed at no charge. (3) That, I'm close to a larger gas line in the street and there is probably no chance of exceeding what the pipe from the street to my house can supply (I live on a large street). But if I DO, then I would have to pay to replace that (at which point I would sell my used tankless heater on eBay and write the project off).
    Anyway, the tech at the utility brought up GAS SUPPLY PRESSURE. The Rinnai docs call for a minimum of 6" W.C. and a maximum of a 10" W.C. She told me they supply 7" at the meter, and that there is an immediate drop after the meter to approx. 6". She was surprised that this unit could require a minimum of 6". I told her the unit would be located approx. 40' from the meter, and she said I should replace my 3/4" pipe w/ 1". Others have said that, too.
    But the question is, what will be my pressure at the end of a 40' of 1" pipe be if it starts at 6" of pressure? Can anyone do the math? I planned on using a flexible gas pipe, to make installation easier. But, I imagine flexible pipe will have a higher drop per foot than solid pipe?
    And another question, which I guess is better put to Rinnai but I'll ask here too, is how can they require 6" as a minumum? Isn't that a rather high minimum?
    Any enlightenment is appreciated.
    Thanks!
    Phil
  • bigsteel15
    • 1079
    • Edmonton, AB
    That doesn't sound right. Generally the meter should be supplying 1/2 lb (14" WC) gas into the house (state regs might restrict that) and then you reduce down closer to the appliance.
    Most NG appliances run @ 7" WC optimum.
    If I had my codebook at hand I could answer your pipe size questions. Will check at home tonight.
    Brian
    Welcome to the school of life
      Intertesting. The lady from WE Energies (or like we call 'em, WEENERGIES), said they supply 1/4-pound after the meter. Maybe she was wrong? She seemed to know her stuff.
      • bigsteel15
        • 1079
        • Edmonton, AB
        I could be wrong...Now you've got me curiuos.
        I will check my regulator when I get home and see if I can find my old code book.
        It's been 10 years since I did gas service work and took the course.
        Brian
