A backed up drain and loose sink trap resulted in water getting through the plywood bottom shelf of my kitchen sink cabinet down to the particle board subflooring a 2x4 width below the shelf. The bottom sink shelf turned out to have been opened up before, with a ragged cut taking up about half its area and exposing the subflooring. The hole had been covered up with a couple sheets of plywood, making a new (but leaky) floor to the cabinet.
Anyway, I took out the plywood sheets, propped them by the front of the cabinet with doors open, and directed a box fan into the area for 24 hours. The plywood seems to be drying out a bit, but the particle board subflooring is still pretty soggy.
Any suggestions? Should I remove the rest of the original 1/2" plywood cabinet floor and then, somehow, remove the wet subflooring, replacing it with something dry and probably more waterproof? Should I just get a heater with fan instead of the plain box fan, and give it another day or two to dry? Anyone been through this before?
