New BT3100 Owner - YEAH BABY!
  • kano32
    • 28
    • Palmer, Alaska
    I bought my BT3100 at Home Depot (yes we have Home Depot in Alaska) yesterday. I had enough time to put it together prior to taking a nap before working the night shift. I was using a 1951 Delta tilting table-table saw that needed a major overhaul. I can't wait to cut some wood with the new saw. Now I have to find a home for the old Delta.
    I love the smell of sawdust in the morning. It smells like...Woodworking.
    http://community.webshots.com/user/kano32
    Welcome Kano. Enjoy your saw and keep posting. We have several police/law enforcement officers here.
    • gmack5
      • 1972
      • Quapaw, Oklahoma, USA.
      • Ryobi BT3000SX & BT3100
      Welcome Kano,
      Congratulations on the acquisition of your BT3100 and welcome to the "family".
      One of the first things you need to do, after you get your BT3100 Saw assembled is, following your Owner's Manual, go thru the entire set-up proceedure, step by step, in the sequence laid out in the Manual. Each set up proceedure builds on the one before it, so you MUST keep them in sequence.
      Regardless of what you've read or others have told you, NEVER NEVER use any wax or lubricant on your saw that contains Silicone, this includes all automobile waxes and polishes and most spray-on furniture polishes. The reason is simple, most of them contain Silicones and they will make your projects difficult to finish.
      If you put it in one place, eventually it will be all over the entire saw.
      Your best bet is to use a "dry" lubricant, such as Teflon (PTFE), Powdered Graphite, or Candle Wax for the Raising/Lowering and Tilt mechanisms below the table top.
      A good one will cost you quite a bit of money, $40 - $100, or more. I would recommend that you consider using a pair of Draftsman's 30 -60 and 45 degree triangles instead. You'll find they're not near as expensive and are far more accurate than a run-of-the-mill Carpenter's Square. The 30 -60 triangle should have one 12" leg and the other leg would be 9" long. The 45 degree triangle should have at least 8" legs on either side of the 90 degree corner. That way either one can be put up against the side of the Saw Blade without touching the saw teeth.
      Just remember, regardless of which measuring instrument you choose to use, check it(them) to be sure they're accurate. When checking the Miter Fence for Square to the Blade with a triangle, use the 12" 30-60 against the Fence, if possible.
      George
        Welcome to the Asylum, Kano!
          Welcome aboard!
          • bigstick509
            • 1227
            • Macomb, MI, USA.
            Welcome
            • Never2old2start
              • Oct 2005
              • 112
              • Orlando, Florida, USA.
              Welcome aboard! Lots of good people here to help you with whatever you need. You're addicted now and you don't even know it.
              ~ Paul ~
              • lcm1947
                • 1490
                • Austin, Texas
                • BT 3100-1
                Yes welcome aboard and I hope you enjoy your new saw as much as I enjoy mine, cause that's alot. Everytime I use it and learn more about it the happier I am I bought it. What a great saw. Anyway welcome again and be seeing you around. Watch those fingers and hands.
                • Otter
                  • 865
                  • Cumming, GA, USA.
                  • Delta Left Tilt UniSaw
                  Welcome...welcome
                  T.E. Lawrence
                  • Wood_workur
                    • 1914
                    • Ohio
                    • Ryobi bt3100-1
                    Welcome! Have fun, and Be safe.
                    Alex
                    • gfrenzel
                      • 51
                      • Sulphur, LA, USA.
                      Welcome Kano. I just bought mine not too long ago. These guys are great and very friendly. Have fun and be safe with your new saw.
                      Garth
                      HE took my nails. <><
                      • kano32
                        • 28
                        • Palmer, Alaska
                        Thanks for the welcome. Has anyone tried the Herc-u-lift on the BT3100? I have a really tiny shop and a mobile base would be great.
                        • RmeDad
                          • 231
                          • Scottsdale, AZ
                          Works great. Many of us have it installed. Use the 28 x 28 instructions.
                          Jack
                          Throughout my racing career I was constantly reminded of this: "Keep the pointy end forward and the shiny side up!"
                          • monte
                            ***** Windbag
                            • 5242
                            • Paw Paw, MI, USA.
                            • GI 50-185M
                            Welcome to the group. Be safe and enjoy your new saw.
                            Monte (another darksider)
                            • kano32
                              • 28
                              • Palmer, Alaska
                              Do any of you know how to insert an image in to a post?
