BT3000 Riving Knife
  • markelkar
    • Dec 2023
    • 8
    • Murrieta, Ca.
    BT3000 Riving Knife
    Does anyone have info on anyone making and selling Riving Knives for the BT3000. I apologize if this issue has been covered in previous posts but I am new to this forum. Appreciate any help or pointing me in the direction of any after market options.
    • 22061
    Welcome to the SawDustZone.
    Here is a PDF you can print 100% scale for correct template.
    The usual build is mild steel thinner than the kerf of the blade. If you are using a .100" or 3/32" Kerf blade then 0.093" or 0.090" mild steel is recommended.
    Aluminum can work, quite well, too.
    Any questions, ask.
    • markelkar
      markelkar commented
      Thank you for your help
    • Fried Chicken
      Fried Chicken commented
      I might send this to my local metal fab place, and maybe get it in two thicknesses: one for regular, one for thin-kerf
    • 22061
    Here's 1 more files I found. THis one has points for attachment of the Sharkguard to the top
    • markelkar
      markelkar commented
  • Black walnut
    • Aug 2015
    • 5514
    You may be able to purchase one from thesharkguard.com. While you are there look at their excellent blade guards. The founder of that small business was one of the first 100 members of the beginnings of where our forum started and was a long time moderator. I believe his son is running the business since Lee's passing some time ago.
      dbhost
      commented
      I was not aware of Lees passing. That stinks. I sort of figured he got tied up with the business... RIP Lee!
    • markelkar
      markelkar commented
    • 22061
    The link to the sharkguard riving knife page is here.
    https://www.thesharkguard.com/produc...and-splitters/
    I think I enquired a couple of years back, the riving knife for the BT3x saws ran about $65 which is showing as the minimum price, but you can get one custom made for the kerf of your blade.
    Not cheap but if you can't scare up the sheet metal and cut it and drill it then it might be worth it.
    • Dedpedal
      • Feb 2020
      • 256
      • Palm Coast Florida
      I recently picked up a 4th BT 3000 with a ton of extra parts and accessories. I found a support for the blade guard that I plan to use as a riving knife.
      • markelkar
        • Dec 2023
        • 8
        • Murrieta, Ca.
        Thank you to everyone for your help, I purchased one from Sharkguard for 65.00. It was a tough cost benefit analysis but since it will help get some more years of use on my BT3000, It was most likely worth it as I do enjoy the saw overall. Also the price is fair for the riving knife even if it is a third of what I originally paid for the saw.
          • 22061
          Glad you got what you needed and wanted and will enjoy your saw.
          • jlmeredith
            • Jan 2012
            • 35
            • Denver, CO
            I am curious if simply modifying the splitter is a reasonable option? I have removed the blade guard completely from the splitter and using the pattern in this convo, I can just modify the current splitter to be the right size and shape. Eventually, I would love to have a Shark, but for now, I think this should work well. Thoughts?
            Jamie M
            Denver, CO
            https://sacredlumens.com/
              • 22061
              Sure, no reason that can't work, just that you can't go back once cut down.
