Global Header
Wrenches are available again!
  • GrumpyDad
    • Jul 2020
    • 165
    • Midwest
    This gentlemen is making wrenches for our beloved BT3X saws. Should have a sample set in hand next week
    I have bought many items from this source. All have been of exceptional quality.
    Highly recommended
    https://www.ebay.com/itm/29498950830...AAAOSwL1xihB9-
    Harumpf!
    GrumpyDad
    • 3040
    Those look really nice. If I still had a BT 3000 series I’d pick up a set
      • 21583
      You really need on of these for the arbor lock if you have a BT3 saw.
      The hex wrench endss are easily replaced by a 3/4 and a 1/2" wrench. But the Arbor Lock end is really handy for the BT3
        • 9405
        I still have the OE wrenches for my saw, but saved this seller just in case...
        • GrumpyDad
          • Jul 2020
          • 165
          • Midwest
          New wrenches received.
          Note the size difference. I like this feature for its clearance from the blade. Although, I have always thrown a rag over the blade in the past when making adjustments and changes.
          Click image for larger version  Name:	20220524_150614.jpg Views:	0 Size:	109.3 KB ID:	850917
          Harumpf!
          GrumpyDad
            • 9405
            I had no idea they were that much longer than the OEM ones... Seriously considering them now...
            • Black walnut
              Administrator
              • Aug 2015
              • 5482
              JMHO the extra long length will lead to over torquing the arbor nut.
                LCHIEN commented
                Good point. I suspect most people overtorque the blade. Doesn't really take much. I use a 3/4" combo wrench, mostly because its more comfortable, but I go easy on it. It is self tightening by virtue of the left handed thread.
              • nicer20
                nicer20 commented
                I had also read that one doesn't need to tighten the nut much because it will self tighten further when turned on. But when I followed that tip, I had the spinning blade stop in the middle of a cut - it was quite scary. So now I tighten the nut quite a bit - although not necessarily super tight.
            • patmac
              • Feb 2022
              • 5
              I bought a set, received them last week. High quality and well made! A little bit pricey, but what isn’t these days.
              Just my opinion….If you need them (like I did…my saw didn’t come with them)…they are an excellent choice, well made and fast shipping!
