Does anyone have the dimensions of said item? I want to make two or more of them. One for 10" blades. And one for 7-1/4" blades. I usually am not cutting anything thicker than 1-1/2" so the smaller blade works for me. I'll check the kerf widths as I have a magnifier with a graduated scale in .001"
Splitter Plate/Blade Guard Carrier dimensions?
Tags: None
Here is the drawing in PDF, IIRC its one to one when you print it scaled full size on your printer (i.e. it can be used as a template). Verify the 1" square reference on the print.
You don't need the slots along the top if you just want a riving knife, the little slots are for mounting the shark guard,
https://www.sawdustzone.org/filedata/fetch?id=843309
this a couple of threads about it, I just pulled the drawing and article from the advanced search on this forum.
https://www.sawdustzone.org/forum/discussions/bt3x00-related-discussions/842109-riving-knife-alignment#post843308
https://www.sawdustzone.org/forum/discussions/bt3x00-related-discussions/855593-idea-for-a-modular-riving-knife-pawls-blade-guard#post855604Last edited by LCHIEN; 09-08-2026, 11:06 AM.
LCHIEN
