Extending rails on BT3100
  • BeauxTi
    • Jan 2012
    • 108
    • Georgetown Texas
    • Ryobi BT300
    Just thinking, I know new Factory Accessories for my saw are not available, readily anyway. Anyone taken a pair of standard front and back rails and used them as extensions? If you have, I would be interested in how you did it and how it worked. If this is a really bad idea, any info you can share on that would also be appreciated.
    Beaux Ti -
    If you see a Bomb Tech running, follow him....
    Internet Fact Checker
    • 20969
    Lots of people have done this. The BT3000 rails are silver and the BT3100 rails are black; they have a slightly different profile so you will want to match them.
    Of course front and rear are different.
    The extension rails are exactly the same as the original rails that come with the saw except no ruler.mounted and the extension rail kit includes some metal bars and some screw to facilitate screwing them together along the back and bottom.
    Some people I know milled 4-5" pieces of wood to fit snugly the inside of the rails and then drilled and screwed the rails from two sides (back and bottom) into the wood blocks.
    It was also common to fit half rail extensions, i.e. not the entire 42 inch length but a sawed off piece either 21 or 24 inches long. Then then sold the cut-offs to others for short extensions. This takes up less space. You may still need some support depending on the length and weight..
    • ballard770
      • Jan 2016
      • 140
      • Washington State
      If you have a pair if rails you can use th3m if you can get the connectors and t-nuts. If you can’t get connectors you can use Stanley ? mending straps that are available and t-nuts that are not Available as far as the Ryobi tnuts. However you can get tnuts from T-nuts.com for about $1.60 each. Tnuts.com also has a half wide table hinge for about $25 that you can use.
      or, keep tabs on eBay and full sized and half size kits are occasionally available for about $90.00. Just search “ Ryobi bt3000 Wide” and you will find them occasionally. Also look at completed listings for rec3nt history of listings.
      • BeauxTi
        • Jan 2012
        • 108
        • Georgetown Texas
        • Ryobi BT300
        Thanks, both of you. Going to start down this road and see where I end up.
        Beaux Ti -
          • 20969
          There's a lot of info on BT3x00 in the FAQ available by clicking the link at the bottom of this reply if you haven't got it yet. A section on the rails is included.
          • GrumpyDad
            • Jul 2020
            • 165
            • Midwest
            Really like this idea...
            One reason I bought my BT3100 is because the building that housed my shop at the time was very small. For most cutting operations, the stock footprint of a BT3100 was about as large a table saw as would comfortably fit. I was also attracted to the space-saving potential of the router mount in the stock accessory table. There
            Harumpf!
            GrumpyDad
              Just me
              • 8439
              I don't know how I missed that thread and those pictures. That is Really Great!
              I RARELY miss something like that. -> Then I looked back on my calendar - I was in a three day transit from Nagoya to Tokyo to Memphis to Dallas back then.
              (I have my calendar of events and meetings going back to summer of '98 when I got my first Palm Pilot - and I kept every thing and ported all events over as I changed platforms and apps.)
              • LaVike
                Handtools only
                • Jun 2017
                • 3
                • Rocky Mountains in Colorado
                By any chance does anyone in the thread posted by GrumpyDad have the plans that LarryG in that thread was sending around?
                If anyone does, can you please send them to me?
                Thanks!
                • GrumpyDad
                  • Jul 2020
                  • 165
                  • Midwest
                  I reviewed the forum posting and located only 1 member who asked for the plans that may be active...
                  os1kne
                  Last Activity: 02-17-2020, 07:12 AM
                  Could the Vbulletin admin reach into a historical archive for the plans?
                  Harumpf!
                  GrumpyDad
                  • LaVike
                    Handtools only
                    • Jun 2017
                    • 3
                    GrumpyDad - Wow! Great idea!
                    This setup seems to be really good and plans would be great!
