BT3000/BT3100 1/2" Handwheel Adapter drawing
    Internet Fact Checker
    • 20920
    I am cross posting this because I think it might stand alone and be easier to find.
    This is the drawing for the half inch Handwheel to BT3000/BT3100 Adapter
    I did not design this, it was sold by an eBayer 7 years ago and I just copied the dimensions. My part was cut in aluminum.
    THere are really no critical dimensions except the small shaft must be less than 0.500" and the cavity should be large enough to fit the BT3000 handwheel shaft.
    Many Handwheels on the market now are metric and have a 12 mm shaft opening... which is like 0.472 inches so it can be made easily for that, too.
    Click image for larger version  Name:	CCI07192020_00001.jpg Views:	0 Size:	73.9 KB ID:	839897
    Click image for larger version  Name:	fetch?id=839891&d=1595117585.jpg Views:	0 Size:	114.4 KB ID:	839898Click image for larger version  Name:	fetch?id=839890&d=1595117582.jpg Views:	0 Size:	107.0 KB ID:	839899Click image for larger version  Name:	fetch?id=839889&d=1595117582.jpg Views:	223 Size:	189.3 KB ID:	839900
    Last edited by LCHIEN; 04-24-2022, 11:35 AM. Reason: Add metric 12 mm size note, fixed typos
    • 20920
    Some more files and pictures for handwheels adapter and the difference between the original BT3000 metal and later BT3000 plastic handwheel
    As far as I can tell the spline around the base shaft of the BT3100 handwheel (right) has no real function.
    click on the pictures to load.
      • 9209
      I don't suppose anyone knows a machinist that can knock a few of these out cheap? This was from an ebayer long ago...
      • GrumpyDad
        • Jul 2020
        • 163
        • Midwest
        The gentlemen in Logan Utah that makes the CNC miter is very interesting to talk to about parts. I can reach out.
        Harumpf!
        GrumpyDad
