Dont give up on looking at the library for printer services, our little two light town with population of <30k has 2 library’s with one having the 3d printers. They have the new technology centers to train students...... but only the library technicians are allowed to operate the equipment. I can’t really see how that’s training students, but it’s obvious I can’t see a lot of things nowadays with my mask pulled up over the top of my nose!
Announcement
No announcement yet.
BT3000 sliding table
I'm going to bump this thread up again. I know someone here was printing the slides and the only digital files I've seen are for printing parts for the rip fence.Last edited by Pappy; 06-05-2020, 01:39 PM.Don, aka Pappy,
This thread is about the SMT sliders. https://www.sawdustzone.org/forum/di...ed-smt-a-slide
The 2 members that were most involved in the design and printing of the modified sliders both responded. atgcpaul was the one that printed them but, unfortunately, he no longer has the capability. I am going to look for a local company that can make them and, if there is enough interest maybe have a small run of them done. I'll post any updates here as I get them.Don, aka Pappy,
Originally posted by Pappy View PostThis thread is about the SMT sliders. https://www.sawdustzone.org/forum/di...ed-smt-a-slide
I really don't like shilling, but I've made replacement slide sets.
They're my own design based on the OEM parts, but slightly different.
Their printed in either Nylon 6/6 or 6/12, so they're silky smooth and wear like iron.
BT3000 or BT3100 Nylon Miter Table Slides (1 complete set) 661845001 661844001
I'll post this in the other threads that I found. Feel free to delete my posts and shove it in a new thread if you feel that's more fitting.
snowmansmedleys I saw your design - I have noticed that my original SMT has a bit of a play side-to-side. Will your new slides eliminate that play?
BTW is this design reversible such that you can rotate 180 degrees to get double the use when one side wears down?
Thanks in advance.
- NG
Originally posted by nicer20 View PostChr's
- 1 like
Originally posted by nicer20 View Postsnowmansmedleys I saw your design - I have noticed that my original SMT has a bit of a play side-to-side. Will your new slides eliminate that play?
Thanks in advance.
- NG
I unfortunately had to choose between robust retainer slides and more available wear surfaces.
I don't suggest doing it, but I've tried to pry the sliding table off the rail in order to snap the retainer slides and I couldn't do it.
If you don't want to replace your OEM slides, you could buy ring shims to stack behind the OEM slides.
https://www.mcmaster.com/shim-washers/ring-shims-7/
