Rip blade recommendation
  • Cochese
    • Jun 2010
    • 1988
    I chipped a tooth on my trusty 24T Freud as I discovered today while cleaning it, and I need a replacement. It doesn't appear the exact same one is available, besides I am looking at the opportunity here to get something that might be better.
    I don't really enjoy getting the red coating on everything when I clean, but I suppose I'm looking at the LU87R010 as an option.
    While I've got your attention, I also have the 40T and 50T blades, and at some point I will look to replace or upgrade. I don't foresee upgrading to a cabinet saw any time soon, so all thin kerf are fine.
    And the last item - I cleaned my other two blades and gave it a spritz of dry lube. It dried white on the blade, should I worry about cleaning it off?
    EDIT - very close to buying the Irwin Marples 24T from Amazon. I've been keeping my eye on these since the first reviews started coming in.
  • jussi
    • 2162
    I have that freud blade and it works real well for me. I'm real lazy though and usually just keep my general use 40T on unless I need to rip some really thick stuff. Not a good habit I'm sure. Perhaps knottscott will chime in. I think he's tried every blade imaginable.
    • Knottscott
      • 3815
      • Rochester, NY.
      • 2008 Shop Fox W1677
      The Irwin Marples or Freud LU87 are both really solid choices....pick your favorite color or best deal. Lowe's has the Irwin Marples for < $30....same price as Amazon. Amazon sometimes drops the LU87 to ~ $36, but current price is ~ $43.
      • phrog
        • Jul 2005
        • 1796
        • Chattanooga, TN, USA.
        I also have that 24 Tooth Freud and love it. thinking of upgrading all my other blades to Freuds because of it.
        Richard
        • Hockeynut
          • Dec 2013
          • 6
          • Fort Wayne, Indiana
          • BT 3000
          I have a CMT 256.050.10 50 tooth and the rips are glue up ready. Smooth as a baby's bottom! Paid 49.99 for it locally McFeely's have it at $41.93.
          • Cochese
            • Jun 2010
            • 1988
            The only thing I don't like about the Freuds is the red coating that IMO too easily comes off.
            Sent from my HTC One using Tapatalk
              • 22063
              one chipped tooth is not the death of a blade. Does it cut any differently? If not you can still use it.
              Some blade sharpening service can also repair chipped teeth, for a few bucks, you have to determine if its economical.
                • 9555
                The Diablo 24T rip blade works great for me. However one chipped tooth isn't nedessarily the death of your blade. Get it sharpened and in operation that tooth should effectively get skipped over... Some shops will actually replace a tooth if need be, but that can be spendy on a rip blade as they usually are kind of disposable price wise...
                • Cochese
                  • Jun 2010
                  • 1988
                  I had read that a damaged tooth was a danger of being a projectile. No?
                  • lrr
                    • 380
                    • Fort Collins, Colorado
                    • Ryobi BT-3100
                    When I decided to keep my BT3100, rather than upgrading to a more powerful 3HP SawStop, I decided I'd get the best ripping blade I could. I do believe the Forrest Woodworker II is that blade. I have used it to rip 8/4 oak and it went thru it pretty effortlessly. I bought the 30 tooth thin kerf blade after talking to Forrest. This blade is recommended for wood up to 2" thick. The 40T is more of a combo blade, and for ripping thinner wood. I also bought their blade stiffener, which was around $25, as I recall.
                    I like this blade so much that I may buy the 40T also.
                    They are not cheap -- $109 for the 30T, and about $124 for the 40T. But the way it cuts makes me happy to spend that kind of money on a blade.
                      • 3787
                      I think that Freud blades are lifetime warrantied, that should include broken carbides, though it might not since it is customer inflicted. It might be worth a phone call to see.
                      capncarl
                        I bought a cmt because I could get it locally when I last needed a rip blade. It is 24 tooth and thin cut. It works surprisingly well. But my full width Freud works fine on the BT3100 too. When clean and sharp both will cut to full depth.
                        I use a mail order sharpening service sometimes. I can't remember the name right now but they also make blades.
                        • Cochese
                          • Jun 2010
                          • 1988
                          Pulled the trigger on the Irwin. Amazon has a 20% off promotion, so it was only $25.42 shipped and with tax. I like how the teeth are bigger than the Freud.
                          I won't bin the Freud for the time being.
                          I also took advantage of that sale by buying a 12" 96T blade for my SCMS. I've been doing very well with the stock blade, but at $50 or so for a 12" blade, I had to upgrade.
                            • 9555
                            Which Irwin did you get? If it's one of the newer blue Irwin Marples blades, keep us posted on the performance of that blade... I have seen good things about them but haven't tried them yet... All my blades are either OE, or Freud Diablo... Okay my round blades that is...
                            • Cochese
                              • Jun 2010
                              • 1988
                              Yes, both the Marples (Italy) blades.
                              1807366 for the 10" 24T
                              1807385 for the 12" 96T
