Shim Fix/Upgrade
  • jhudge
    • Jan 2005
    • 7
    • Cypress, TX, USA.
    Shim Fix/Upgrade
    After having looked around the site for the last couple of weeks, I finally decided to join. Just in time, as I have finally encountered the shim problem on my BT3000. I remember seeing something about a fix and/or upgrade, but as is typically the case, I can't find it now that I need it. Can anyone out there offer advice on the best way to tackle this?
    Thanks
    The conversion is easy, no ,ore difficult than putting back in the old style shims.
    Here is what you need:
    2 ea #0181010314 spring shims (BT3100)
    2 ea #969600001 flat shims (BT3000/BT3100)
    1 ea guide holder #0181010110 (BT3100)
    I would suggest that as long as the saw is torn down that you replace the belts.
    2 ea #662329001 (BT3000/BT3100}
    Some have had a problem seating the new guide holder on the bearing race. It is not a push on fit by hand. I used two small Quick Clamps to seat it.
    The parts are available through:
    www.ordertree.com east of the Miss. 877-500-7499
    www.bilious.com west of the Miss.
      http://www2.gol.com/users/nhavens/ht.../shims1-e.html Link to Norm's Shim supports. A permanant fix retaining the origional shims (only applies to the BT3000)
        • 8793
        Welcome Jhudge! With you being a BT3000 user, it is probably safe to say that you have been woodworking for at least a little while. Join in the fun here and be sure to post some picts of your work. Your contributions and questions are welcome!
        • Ken Weaver
          • 2417
          • Clemson, SC, USA
          • Rigid TS3650
          Welcome aboard Jhudge!!
          Ken Weaver
          Clemson, SC
            jhudge, I sent you an email about the process. I just finished it myself.
            • bmyers
              • Jun 2003
              • 1371
              • Fishkill, NY
              • bt 3100
              I have one of these I can sell you cheaper if you want it..
              I'm parting out a BT3100. Email me.
              • norrodb
                • 22
                • Crafton, PA, USA.
                I have the Shim upgrade package listed on EBAY if anyone is interested.
                http://cgi.ebay.com/ws/eBayISAPI.dll...sPageName=WDVW
                Thanks,
                Brent
                Brent in Pittsburgh
