I've had my 21829 for a bit over a year now and it's been a fine tool. But I think it's high time I took it to the next level. The stock form has some shortcomings I have wanted to address for awhile, and I finally think I'm ready.
I want to build an outfeed table first of all. I'm thinking about a 6-panel interior door, covered in hardboard and trimmed. I think pelligrini had a good idea and I am going to borrow some of that. I think it will store on the shop door, and I may set up something in the shop where it could also be a temp assembly table if needed.
I also want some extra width for wide cuts and stability. I would like some half-rail extensions, but could also do something that involves a separate rolling cabinet (router table?) that has an alternate method of registering a fence. I want to make extension tables to fill the space, and make miter slots to enhance/replace the SMT. I want to use some standard miter accessories including a sled. I have the slots and the bars.
I'm currently reading through past threads for pictures and construction ideas, if you have any links or pictures that I might find useful, I would appreciate it. Keep in mind I have a ~6' access height on the door and a ~7' ceiling height. I would like to keep the mobile base and be able to wheel the whole contraption down the ramp and outside for full sheet rips. Thanks.
