...because the set screw (which needs to be all the way in to create enough clamping action) catches and won't release. When the rod pushes the set-screw, it swings out and up, and then it catches on the top of the black plastic housing that is around it. I have to unscrew it 1 cm or so just to allow the clamp/hinge to swing freely in order to get the rear of the fence off of the rail.
Anybody else deal w/ this? Ideas for fixing? I did straighten the front cam tab already.
Sorry for reposting, just figured that w/ 130 looks and only 1 reply that maybe someone would give it another look.
Thanks!
Thanks!
