Hello,
I was building a bench and found a need to "trim some 12.5x12.5 in panels by about 1/8th of an inch, so I decided to try the SMT again, which has plagued me in the past. I found that again, my cuts were off by about 1/16-1/8" over the 12" panel.
I decided to try again to align the SMT, but this time, I had my neighbor join me just to verify I wasn't losing my mind--he's a smart guy and has done some carpentry and basement finishing, so he's not a stranger to tools by any means.
I check the SMT sled base against the blade and we both agree that according to my dial gauge, there is .0015" variance. That's 1/2 the thickness of a piece of paper for reference--should be well within normal tolerances. Then, we set the fence at 90 degrees to the SMT top. Next, we checked the fence and found it was out every so slightly, so we aligned the SMT using the eccentrics and a plastic drafting square. All good and tightened things up and re-checked.
We both made test cuts. Neither of us could get a square cut after about 1.5 hours of trying, adjusting, and using different hold techniques.
I am now officially delerious and completely over the whole saw.
). Put on miter slots and got an Incra miter gauge, and the old BT was reborn. I'll have it forever, even after I bring in a new Uni someday when business picks up again...
