BT3000 motor testing
  • sscherin
    • 772
    • Kennewick, WA, USA.
    Does anyone know how many ohms I should see when testing the coils in the motor?
    It's the 15a motor. It ran slow but I'm not sure if it was brushes or a fried coil.
    William's Law--
  • Hoover
    • 1273
    • USA.
    R=V/I V=120 volts I=Amperes 15 R=8 ohms
    No good deed goes unpunished
      • 22075
      i don't think that's what you'll measure. Reactive AC current is different than the DC current seen by a voltmeter.
      I'm guessing your ohmeter wull see much closer to zero ohms, maybe around 1 or 2 ohms, offhand.
      • sscherin
        • 772
        Yeah I'd expect a result in the .5-2 ohm range much like testing the stator on my motorcycle..
        The plan was to check resistance between windings.. less than ?? ohms (.5 is the low end of then range on my GS1000 Stator) indicated a short in the windings..
        2nd test winding to armature checking for a winding shorted to the armature..
        I guess the best thing would be to test a known good motor and compare to the other one I know has some problems..
        William's Law--
