I shredded the belts on my saw, so I don't know what the old ones looked like. I bought some new ones, and I'm a little puzzled. Maybe someone can shed some light.
The belts look like "toothed" belts, whereas the spindles are of the multi-v type. What is odd is that the belts have very slight multi-v grooves on one side and teeth on the other. If I turn them so that the teeth run on the outside, they look like they would work.
Are these belts designed to run with the teeth on the outside--away from the spindles? Seems odd to have the teeth on one side and grooves on the other. Is that right?
Thanks!
Thanks!
