Well, here is another thread on this problem. I read through a few other threads to see what other people had done, but could't seem to get the back of my fence to lock down. I made sure the lip was in the channel, tightened the adjustment screw, etc. Nothing helped. When I pushed stock tight against the fence, it would deflect as much as 1/4" at the back.
I discovered two things right away. When I engaged the locking handle, the lip on the back of the fence barely moved, maybe a couple thousandths of an inch at the most. And even when the adjustment screw was tightened all the way down, it would not engage the back rail.
The first thing I did was go down to my local hardware store and get a longer screw (it is just a 10-24 pan head screw - I got 2" screws to replace the original). That allowed me to adjust the screw far enough to make the lip engage the rail. The only problem now is that I have to adjust it so close to the rail to get it to engage when I tighten the handle that the fence will not slide smoothly when the handle is lifted.
After taking apart the fence and inspecting it, I think I know what the problem is, but I am not sure what the fix will be. If you look inside the front part of the fence, you will see that the handle operates an eccentric cam. In addition to locking the front of the fence to the front rail, the cam raises a small lever against the rod that runs through the fence. This pressure against the rod is what is supposed to engage the lip on the rear of the fence against the rear rail. The problem is that the surface against which the lever rides has worn down, and so instead of pushing toward the back of the fence, it rides almost straight up and down. This limits the "throw" of the rod to a few thousandths of an inch.
In order to correct this, I am sure I need to shim the surface in some way so that the lever pushes the rod toward the rear of the fence again. I only need to gain about 1/32" throw. Any suggestions? I tried glueing plastic shims in, but they didn't slope toward the back of the fence, so the lever continued moving straight up and down, just a little further out.
I thought about cutting a very small wedge-shaped piece of hardwood and using that as the bearing surface, but I don't know how I would attach it to the aluminum surface.
Does any of this make sense?
