$2.00 3-inch free-wheel casters TiP
    • 8720
    Technically, this is not a bargain as it is not currently available, but this probably will be on sale again for $7.99 at the end of December and in magazine ads:
    http://www.harborfreight.com/movers-dolly-93888.html
    I purchased two of the dollies this past weekend and intentionally bought one for the casters only. I removed them and they are much cheaper than any other 3-inch wheels at HF.
    This is currently $11.99 at HF but as mentioned was on sale this past weekend for $7.99.
    Look for the sale that should be coming up at New Years, as it might be available. Sometimes they are in coupons that are in magazines, and in some "Inside Track Club" coupons.
    I should get one more set for my needs. Cheap - compared to regular priced and even on-sale casters.
    As a side note, I looked at the wood that makes these up and found one that had some "curly" wood in it and will probably use that for a pen!
  • tommyt654
    • Nov 2008
    • 2334
    Good idea Hank, and I know a way to make a cheap lock for those even tho they have none. Looks to be load rated high enough to use on about anything.Thanks
    • jdon
      • Feb 2010
      • 401
      • Snoqualmie, Wash.
      I got one of these last week to help move some of my in-laws furniture. The casters were terrible- they wouldn't swivel even when supporting a lightweight dresser. Holding the platform vertically the casters wouldn't even turn by gravity. Maybe with some lubrication and TLC they might have worked, but I ended up returning to HF for refund (and carrying the furniture). I have doubts about their ability to swivel under a heavy load such as a stationary power tool.
        • 21820
        i have once of the cheap hf dollies as well, the casters aren't really all that good, they are hard to steer so I assume its a non-smooth swivelling problem like JDON suggests.
        • toolguy1000
          • Mar 2009
          • 1142
          • westchester cnty, ny
          and that way of making a cheap lock would be.......?
            • 8720
            Wow, Mine are in good shape and work FINE. My 8 year old twin grandsons were here over the weekend too and guess what they played with on the driveway - the two dollies. I took one apart after they played with it! Neither were overly loose or too tight in the swivel and both rolled well and the boys played on it like a skateboard!
            I guess this is one of those HF products that will be good for one fellow and bad for the next. I am considering myself lucky!
            Adding in, I have a LARGE furniture dolly (28" by 42" with 5" casters) that I made about 6 years ago and it handles my sofas and dresser type of moves. This HF one is for lightweight stuff, not anything that will hang over the sides and throw it off balance.
              • 10479
              jdon and Loring hit why cheap casters are best left on the shelf. The wheels will normally roll ok and handle the rated load, or close to it. The problem is there is a sinble row of bearings in the swivel and even that will have a gap equal to at least one bearing size. Add por tolerances on the center rivet and the caster will flex and bind when it has to swivel.
              • tommyt654
                • Nov 2008
                • 2334
                Since these are usually attached to a frame made of 2x4 I simply attach another piece of lumber preferably a 2x2 to the inside with a few strap hinges that allow it to hang down near the wheels and put a T-nut in the 2x2 and drill a hole thru the 2x4 frame and run a bolt thru a washer and the 2x4 to the T-nut and tighten it to clamp pressure on the 2x2 as it rest against the wheels.
                • IWannabe
                  • 33
                  • MD
                  For those who are in the HF mailing, there was a coupon in the November issue that had the 3" casters on sale for $1.79 (regular $4.99) for Item 66360/41516. No brakes, limit 8.
                  http://www.harborfreight.com/3-inch-...ter-66360.html (website shows $2.99 sale price)
                  HTH.
