Workforce workbench at Home Depot
  • ryan.s
    • 785
    • So Cal
    Just noticed this today. Workforce workbench with hardwood top and metal base with casters. 135lbs. assembled. I know work force is not a quality brand but for the price I might try it out. Seems solid at 135lbs.
    Normally $117 on sale for $39.
    http://www.homedepot.com/prel80/HDUS...gll.0&MID=9876
    Not sure if the link will work but do a search for workbench on the hd website.
  • parnelli
    • 585
    Internet/Catalog # 100141535
    Brand Workforce Model # T54062
    Assembled Depth (In Inches) 57
    Assembled Height (In Inches) 12.4
    Assembled Weight (In LBS) 135
    Assembled Width (In Inches) 23
    UPC CODE 615268540627
    Even assuming that they've got the H-W-D all messed up (it can't be 12.4" high!), does that mean the table top is ~1ft by 2ft??
      • 22098
      assuming it's not totally messed up I would guess the top is 57" x 23" (wdith and depth reversed)
      and they have the height messed up, usually around 32-38 inches for a bench.
      • ryan.s
        • 785
        • So Cal
        yeah, it must be a typo. i'm planning on picking up one of these today. i'll let you guys know for sure what the dimensions are if i do.
        • messmaker
          • 1495
          • RICHMOND, KY, USA.
          • Ridgid 2424
          I wonder if you could put a router in it. Would the top stay flat enough,you think?
          • ryan.s
            • 785
            • So Cal
            Well I went back to pick up the workbench today. This time I took a look inside one of the boxes and was a bit disappointed. The base of the table looked good, it had a powercoated finish, but the table top was 2 3/4inch pieces of birch ply laminated together. The box cleary states hardwood work surface, I guess technically it does have a hardwood surface but not what I was expecting. I passed on it. Maybe if the price goes down a little more I could get some use out of it. I noticed it was previously marked down to $79, now $39, maybe it'll drop some more. The locking casters alone are probably worth the $39, but since I don't have a real need for it, I'll wait.
            • NJFrank
              • Jun 2003
              • 101
              • NJ, USA.
              I have one for $39.00 it's well worth it. put a plywood shelf in the bottom for some additional storage.
              Don't mistake it for a true woodworkers bench though.
              Never mind just read your last post
              • ryan.s
                • 785
                • So Cal
                Is the table top pretty flat? Is the overall construction of the bench sturdy? Thanks!
                  Ryan,
                  I have one similar that LOML got from Lowes. I took the 3/4" MDF top and added some 1/2" ply and then some scrap laminate flooring on top of that. It is as sturdy and flat as I could want.
                  • Russianwolf
                    • 3152
                    • Martinsburg, WV, USA.
                    • One of them there Toy saws
                    what are the correct dimensions?
                    Lakota's Dad
                    • btompkins
                      • Jan 2005
                      • 21
                      • Prospect, KY, USA.
                      Sad to say that none of the HD's have this in stock in the Louisville, KY area. I called and they searched for me.
                      To bad as I was thinking of adding a couple more layers of birch ply, making a hardwood skirt around the edge and maybe putting on an end vise. Would be a nice little portable workbench and place to park my dewalt planer.
                      • NJFrank
                        • Jun 2003
                        • 101
                        • NJ, USA.
                        OK for those who asked, the Dimensions are as follows;
                        40 3/4" H x 20 D x 53" W Table top is 1 1/2" Laminated Wood Type unknown, seems like a poly finish.
                        Top is Flat on mine but it hasn't seen heavy use. It meets my needs in a small basement shop where everything is on wheels.
                        • JoeyGee
                          • 1509
                          • Sylvania, OH, USA.
                          I found a store with 3, but they are marked at $79. Anyone have a receipt to post?
                          • ryan.s
                            • 785
                            • So Cal
                            I was at HD today and noticed the bench was marked back up to $79 from $39. I also noticed 3 more boxes I didn't see before. I've never seen a closeout item go back up in price.
