what would be the easy and cheap source of some steel strips
    • 21776
    .150 to .180 thick. (approx 4 mm)
    .250 to .265 wide (approx 6.3-6.7 mm)
    a few inches long (at least 2 inches)
    Probably needs to be steel and not aluminum. Mild steel OK or better.
  • Black walnut
    Administrator
    • Aug 2015
    • 5494
    Sounds like shim stock. Check with any well stocked industrial supply house. MSC, McMaster-carr, Grainger, or fastenal. You probably have a local independent as well.
      LCHIEN commented
      shim stock way to thin, way to expensive
    • 3724
    Probably in your file cabinet. Hanging file folders have steel strips about that size. Now if you have gone paperless, that’s a problem.
      dbhost
      commented
      4mm is kind of thick. Maybe those steel strips doubled up would make 4mm...
