And I Thought My Original Plan Was Expensive
  • woodturner
    • Jun 2008
    • 2049
    • Western Pennsylvania
    Originally posted by master53yoda
    quote me the code, 352.24 simply states that the bender needs to be certified to stop people from using a torch on the pipe and getting inconsistent bends, using a shut off BBQ provides even heating and insufficient to burn the pipe.
    Given your experience level, you may well be able to bend PVC conduit in a way that does not violate NEC. Not sure how your BBQ could be "certified" under the code section you cited, though.
    In my experience, the more common situation is that someone inexperienced tried to heat it to bend it and overheated it, resulting in scorching and damage to the conduit. That is what an inspector will flag and fail, in my experience.
    If one really needs to bend conduit (or any PVC product), many people find it easier to use hot water or steam to soften the PVC. A PVC bender can be made from a larger diameter pipe, capped at ONE end, and fed steam from a steamer, tea kettle, or some other source. The hot water and steam will soften the PVC but will not scorch, discolor, or chemically alter the PVC, so it remains watertight and viable.
    • master53yoda
      • Oct 2008
      • 456
      • Spokane Washington
      sorry woodturner I'm not biting your stuff anymore I'm to busy driving nails
      Art
        Could you use a PVC bulkhead fitting? I've seen them used in aquariums a lot. They would be waterproof.
        http://www.aquaticeco.com/subcategor...khead-Fittings
        http://www.plumbingsupply.com/bulkhead.html
          • 4715
          Folks a couple of you in this thread have had posts deleted and we as the forum Staff owe you an explaination of sorts. First they were off topic per the OP. Second they were argumentitive and that is simply not going to get a pass. We because of the recent arguments are trying to prevent more of the same. All members need to be careful that what they post does not attack or demean other members in any way. Each should also ask the simple question "does what I'm posting actually add to the discussion at hand in a positive way?" before clicking the submit button. All things considered we have some of the webs friendliest members that are helpful and kind to each other. We wish for this to continue. If you have any concerns about moderation feel free to contact any of the staff by PM or email. We do not enjoy deleting threads or posts except those that contain SPAM. Most of what we do is behind the scenes.
          Differences of opinion are going to happen. In reference to the many codes it happens. When it does happen it is fine for two members to state their interpretation and leave it at that. The forum readers should then do thier own research with local inspectors if they are not clear on local interpretation. So one post, one rebuttal and then move on. We are not all always right, nor are we all always wrong, but some are
          • Crash2510
            • 830
            • North Central Ohio
            hey crockett
            you could also use 2" emt compression fittings and seal them up with what we in the business call seal rings
            you can also use these with pvc as meyers hubs are pretty expensive
            I dont particularly care for the locknuts with the gasket on them because they are a PITA to put on.
            THese
            http://www.grainger.com/Grainger/ele...search&sst=All
            Phil In Ohio
            The basement woodworker
              Phil,
              How do those work?
              Do they go on in addition to the lock nut at the enclosure?
              • Crash2510
                • 830
                yeah you just put them on the male adapter on the outside of the panel tighten the locknut down on the inside and as you tighten it it gets water tight
                Phil In Ohio
