A Fun Quiz...Really
    A Fun Quiz...Really
    Here's a fun quiz. I only scored 18 on this one. See what you get.
    Neat quiz. I got 20.
      So, David, after the two quiz's, you are an established "genius". I gotta know what you figured out to do with the pole in the "cement".
      • Mrs. Wallnut
        Bandsaw Box Momma
        • 1566
        Okay my brain hurts from all this thinking....and again I won't tell you the score I got on this one either
          No, I've just taken a lot of these quizzes.
          I will see if it is possible to dig the pole out before I cut it. What I really want to do is leave it there and hang a basketball goal on it but SWMBO says it must be moved.
            So where's the answer key?
            • JeffG78
              • 389
              • Sun City West, Arizona
              I'm up to 31 so far
              Oops, typo. I have 31/33, not 33/33.
                It's at the bottom.
                  It's at the bottom.
                  Found the score; looking for the cheat sheet.
                    I couldn't find the "cheat sheet" either. The ongoing answers "border" red for wrong and fade if correct is the best I could decipher. I'll lose some sleep over it but not a lot.
                    • JeffG78
                      • 389
                      Okay, I got them all finally. What do I win???
                      • MilDoc
                        19, then gave up in frustration. One reason I don't do crosswords, jigsaws, etc.
                        • guhor
                          • 20
                          • blountville, tn
                          I sent this to my brother and I had 26 correct and he had 28 correct. We swapped information and together we had 31 correct. He told me he would cheat and sent all the correct answers in about 2 minutes. It seems this was a Mensa test in 2005 and number 30 and number 31 were obviously aimed more toward the European market.
                            I need the answers to numbers 14, 28, 30, and 33. I could probably figure 'em out using Google, but it may be easier to ask here if someone else has already figured them out.
                            I have the other answers in case anyone needs 'em.
                              why not just post them all here?
