Mortise and Loose Tenon video w/ plunge router.
- Created by: drumpriest
- Published: 02-10-2007, 01:10 AM
- 9 comments
Mortise and tenon is a hallmark of craftsmanship, but it doesn't have to be painful. This type of joint can be made easily with no "special" equipment, such as a mortiser, or a tenoning jig. There are as many ways to do M&T as there are to skin a cat ( I suppose, never skinned a cat though ). My personal favorite is mortise and loose tenon with my bosch plunge router.
Mortise and loose tenon VS traditional mortise and tenon:
The difference between these two joints is that with a loose tenon joint, you cut mortises on both pieces (apron and table leg, for instance), then you cut a seperate piece of wood to use as the tenon. In the traditional joint, you cut away material from one piece (apron, for instance) to reveal the tenon. This is somewhat tricky as the fit is dependant mostly on these cuts. With a tenoning jig, any error is doubled, and you go through quite a few test cuts before getting a good fit. With a loose tenon, you can just plane or drum sand the stock down to the proper thickness, which is easily acheived.
Cutters:
You can cut the mortise with a plunge router, and any plungable straight bit, I personlly much prefer a spiral bit. You can plunge the extents of the mortise on the sides, which allows for freehanding the mortise while still acheiving a great fit. That and a round over bit in a router, and making the tenons is a breeze. Keep in mind that these cutters will vary a little in size, so it's a good idea to use calipers to get a good fitting tenon.
The video:
Here is a link to a video showing how to make the parts of this joint...
Tags: NonePosting comments is disabled.
Categories
Article Tags
- BT3x00 (71)
- bt3000 (5)
- bt3100 (2)
- cordless (1)
- diy (2)
- dust collection (11)
- Fence Attachments (12)
- General (5)
- Hand Tool Accessories (3)
- Hand Tools (14)
- Measuring & Layout (6)
- miter fence (2)
- Mobile BT3x00 (9)
- Mobile Tools (9)
- Other Reviews (4)
- Other Tools (5)
- Power Tool Accessories (28)
- Power Tools (75)
- rails (3)
- rip fence (4)
- safety (5)
- Sharpening (4)
- t-nut (3)
- wide table kit (2)
Latest Articles
by LCHIENSo you want to buy a BT3 clone. Been out of production for a while. Shopping on Craigs list or for sale ads is hard
You have to keep an eye out and you have to be used to spotting the appearance giveaway features of the various models... Ryobi BT3000, BT3100, Craftsman 22811 and 21829
There are certain things that clue you in and there are many ads that don't give model numbers and have crappy photos. Search for keywords RYOBI, Precision, System are often used in ad listings and...-
Channel: Tutorials & How To
12-20-2022, 01:53 AM -
by LCHIENDo you guys know your router bits?
Do you know how to tell a plunge bit from a non-plunge bit?
A non plunge bit has cutters around the periphery, but not the center. It can enter grooves from the side and cut moving sideways.
A plunge bit has cutters that go all the way to the center of the bit face. It can cut moving vertically as well as sideways.
Above see the bar across the center as well as the two edge cutters? Without this bar, when you drive the...-
12-22-2020, 04:09 AM -
by twistsolI was in the shop this weekend and was trying to figure out the math for the settings on the Festool Domino to space the mortices evenly and centered across a cabinet front to back. After a bunch of trial and error with my math, I gave up and got close enough and cut the Domino slots for most of the cabinets before my shop time ran out. It was still bugging me, so I figured it out on the plane on the way to work.
Very simply, we need to subtract the width of all mortises created from...-
01-29-2018, 12:46 AM -
by Sam ConderWhile attending a "fundamentals of woodworking" class taught by Marc Adams at the Indianapolis woodworking show a few years ago, I was most impressed with his simple yet effective method of sharpening woodworking chisels. I contacted Marc and asked him for permission to write an article for BT3Central on how to sharpen chisels using his method. As expected, Marc was very receptive to the idea of sharing one of his "secrets". His exact response to me was " Absolutely, please feel free to teach anything you learned from me." So let's dive right into this and sharpen some chisels.
04-29-2015, 10:15 AM -
by LCHIENMost common places to use air fittings in a home shop:
Air compressor to hose or female QD fitting
QD female fitting or male stud to hose
male stud to tool (such as - air nozzle, nailer, screwdriver/drill/impact driver etc, spray painter)
any semi-permanent 1/4" NPT to 1/4" NPT fitting
To add to the confusion, there's nothing on a 1/4" NPT that really measures 1/4". THe threads are visibly tapered and the overall outside size of the male NPT...-
04-29-2015, 10:14 AM -
by LCHIENDigital calipers like these are available for 10-30 dollars. The size quoted as in "6-inch digital calipers" refers to the maximum measurement. The resolution and accuracy of these are typically .001 or one-thousandth of an inch. Some have an additional digit that shows 0 or 5 for half a thousandth. I recommend the six-inch Harbor freight ones, they work very well and are of surprisingly high quality. The stainless body ones are better than the composite plastic body ones although the plastic ones ...
04-29-2015, 10:13 AM -
The SawdustZone Statistics
Topics: 61,270
Members: 20,614
Active Members: 74
Welcome to our newest member, Havoily.
What's Going On
There are currently 11462 users online. 1 members and 11461 guests.
Most users ever online was 11,606 at 02:28 AM on Today.
Footer Ad
Why were you redirected to this page? When we visited this site, we found it may be designed to trick you into submitting your financial or personal information to online scammers. This is a serious security threat which could lead to identity theft, financial losses or other dissemination of personal information.
I have never seen this warning from Mcafee in over two years usage. This doesn't really express how it looked, just the verbiage. The webpage was filled with red 'x''s repeated warnings, etc.
However...
swordandspiritsoftware.com.dish5027.net.ibizdns.co
is entirely NOT correct!
it's ...
so how it got corrupted, I have NO idea, perhaps when the server changed over??
