Frued LU88R010
Purchased this blade 2 weeks ago when Amazon had them reduced. While I can't compare to a WoodWorker II, the blade performs very good for me. I recently ripped some 1" curly maple, paduak and tiger wood with no chattering, binding, burning and nearly no saw marks. It cuts through these woods like butter and crosscutting is even better. Absolutely no tear out (slowed down near the end). I was having a some problems with burning, especially with the padauk prior to intalling this blade. The ripping capability is pretty impressive given that this is a 60T blade, although the hook is 15 degrees.Posting comments is disabled.
Categories
Article Tags
- BT3x00 (72)
- bt3000 (5)
- bt3100 (2)
- diy (2)
- dust collection (11)
- Fence Attachments (12)
- General (5)
- Hand Tool Accessories (3)
- Hand Tools (14)
- Measuring & Layout (6)
- miter fence (3)
- Mobile BT3x00 (9)
- Mobile Tools (9)
- Other Reviews (4)
- Other Tools (5)
- Power Tool Accessories (28)
- Power Tools (75)
- rails (3)
- remote control (1)
- rip fence (5)
- safety (5)
- Sharpening (4)
- t-nut (3)
- wide table kit (2)
Latest Articles
by
twistsol
Summary
Channel: Tool Reviews
by
LCHIEN
by
twistsol
by
twistsol
by
LCHIEN
by
LCHIEN
The SawdustZone Statistics
Topics: 61,764
Members: 20,847
Active Members: 28
Welcome to our newest member, kcwfurniture.
What's Going On
There are currently 5023 users online. 3 members and 5020 guests.
