BT3000 Belt Replacement and Shim Adjustment Instructions
  • BT3000 Belt Replacement and Shim Adjustment Instructions
    Instructions from Ryobi Technical Support
    Submitted by Jim Frye
    The following document is transcribed from the sheet that Ryobi Technical Support sends out if you request belt-changing instructions. It also contains information about adjusting the setscrews that hold the guide holder shims in proper alignment and instructions for taking the motor out. Ed Ellickson (see his article elsewhere on this site) expanded on this article to make belt changing even easier. Ed’s article should accompany this one for anyone planning to change their own drive belts on the BT3K.
    BT3000 Repair by Ryobi
    Have you ever completely disassembled a power tool to replace a minor part, only to discover that there was an easier way to complete the repair in half the time?
    Ryobi’s BT3000 10” Table Saw is one of those tools, with multiple parts and adjustment points, on which repairs can become unnecessarily time consuming if you don’t pre-plan logically. All operational and squaring adjustments are simple operations, fully explained in the videocassette and/or owner’s manual supplied with each saw. However, the replacement of parts associated with the motor assembly is likely to become time-consuming if the proper procedure isn’t followed.
    The BT3000 transmits power from the motor to the spindle through two V-belts aligned side by side on a pair of pulleys. Continued and/or prolonged blade stalling and extended use may lead to belt wear and breakage. Due to the position of the V-belts, belt replacement is not a function that will be performed by the user. A service technician can replace one or both belts in as little as twenty minutes when observing the following procedure:
    1. Remove throat plate (ref. #76), blade guard assembly (ref. #95), and blade (ref. #500).
    2. Lower spindle to lowest position remove left cabinet panel (ref. #9), turn saw upside down, and remove dust cover (ref. #12).
    3. Remove guide holder (ref. #80) and four shims (ref. #3 & #86) by removing six screws (ref. #87 & #89) and tapping on spindle with a soft mallet while pulling guide holder out.
    4. At this point, belts are easily accessible and may be removed by walking them off, one at a time.
    5. After walking new belts onto the pulleys, reverse the above procedure to reassemble. (Here’s where Ed’s article comes into play)
    NOTE: The shims must be replaced in the same position as they were removed or binding will occur. Follow this procedure:
    1. Place a small dab of grease on the inside of the shims to keep the shims in place on the holder (ref. #11 on motor breakdown) and locker bracket (ref. #10) while the guide holder is being secured.
    2. After the guide holder is reassembled, apply light duty Loctite to the four set screws (ref. #73) and tighten until they make contact with the shims, and then back them off 1/8 of a turn. Over tightening the setscrews will scar the shims and possibly cause binding.
    3. Once the setscrews are proper positioned, try to move the motor assembly from side to side. If any play is detected, tighten the setscrews slightly until all movement is eliminated.
    Any work performed on the BT3000 motor assembly, such as armature or bearing replacement, requires following steps one through three above in the procedure to replace V-belts.
    1 - 3. Follow steps outlined above. This allows access to the holder (ref. #11 on motor breakdown).
    4. Remove the four pan head screws that secure the holder to the motor housing. Then remove the right cabinet panel (ref. #8).
    5. You will now be able to separate the motor housing from the holder to replace any defective parts within the motor assembly.
    Questions regarding repair, adjustment or use of the BT3000 may be directed to Ryobi’s Technical Services Department at 1-800-323-4615, ext. 3380.
    Original PDF Document:
    ryobibltrpr.pdf
      Posting comments is disabled.
    Latest Articles
    • Screw friction products EZ-Grip and Screw Grab?
      by LCHIEN
      I was reading an article about fasteners the other day.
      They mentioned a couple of products I had not heard of before:
      EZ-grip and Screw Grab
      Apparently if you have a screw that you have a hard time engaging like a worn Phillips, a drop of these products will increase the friction between the screw and the driver 8X it is claimed so that you can back out the screw.
      You can find them both at Amazon.
      Not cheap 5 oz of EZ-GRIP is $20; 1/2 oz of Screw...
      04-07-2022, 10:58 AM
    • A Cure for the Shim Problem on the Ryobi BT3000
      by twistsol
      Originally written by Norm Havens and re-posted here.
      Editor's Note: The site where this article appeared originally is now gone. I had this article saved as a .pdf file from years ago and resurrected the article from that.
      December 3, 2000 I must be totally star-crossed this week . . .
      "Trouble comes in threes," didn't someone say? This week I've already dinged the blades of my new planer, nearly dropped my router from the accessory table, and now...
      08-29-2018, 11:21 AM
    • Ryobi BT3000 and BT3100 Manuals
      by twistsol
      The manual from the old site is out of date and many of the links in it were broken. The downloadable .PDF manuals are attached below.
      11-21-2017, 10:23 AM
    • Lonnie's No Measure Alignment procedure
      by Lonnie in Orlando
      Hi Guys - I haven't been on the forum much lately ... I bought a '55 MGTF-1500 that is taking up space, time, and money that is(was) used by my woodworking shop. The car has a wood frame beneith the body panels, so I guess it counts as woodworking. Thanks for resurrecting my No-Measure alignment thread. I see that it has lost some of the attachments. So I reposted it below. Note - there are a lot of good ways to adjust a BT3K or any other table saw. This is the one that I found is best for...
      04-29-2015, 09:49 AM
    • BT3K Shim Replacement
      by Black wallnut
      Since it seems time for my semi-annual maintenance and due to several posts asking how to lately I deciced to take pictures during mine. Keep in mind this is specifically for the BT3000 only.
      Step 1: double un-plug saw at outlet and onboard outlet. Remove throat plate, Sharkguard, Big dog clamp, and splitter (or the stock POS []). Remove blade and spacers.
      Step 2: remove left side cover and dust shroud.
      Step 3: remove the four...
      04-29-2015, 09:41 AM
    • BT3000 To 3100 Shim Upgrade
      by crokett
      Upgrading the shims avoids the issue of the BT3000 shims dropping out and causing the blade-raising mechanism to bind.
      Before you begin:
      Call Ryobi technical support at 1-800-525-2579 with the serial number from your saw to
      verify that your saw is eligible for the upgrade. Some earlier BT3000s are not.
      ‘Right’ and ‘Left’ designations assume you are starting by looking at the front of the saw.
      These instructions assume a stock
      04-29-2015, 09:33 AM
    The SawdustZone Statistics
    Topics: 61,288   Posts: 558,598   Members: 20,633   Active Members: 68
    Welcome to our newest member, Foster Kingston.
    What's Going On
    There are currently 7060 users online. 3 members and 7057 guests.
    Most users ever online was 11,606 at 02:28 AM on 03-29-2024.
