Rod Kirby's Miter Slot For The BT3000
  • Rod Kirby's Miter Slot For The BT3000
    Rod Kirbys Miter Slot (Fence) For the Ryobi BT3000
    Hey Guys, this is not a difficult thing to make but it takes a lot of words to describe how to do it. Use the photos with all this text, and Im sure youll find it very straight forward.
    If some of the sizes look funny, its because here in Australia we work in millimetres and I have converted for you. I really feel sorry for you its soooooo much easier than using inches.
    You know the drill, folks read ALL of these instructions first.
    Approach:
    I wanted something which I could adjust precisely, lock securely, and be easy to attach and take off. The adjustments took the most think time, but ended up being quite simple.
    Hardware:
    Qty Item Purpose
    2 6 long x 2-3/8 x 1/8 Aluminum angle Brackets
    4 3⁄4 x No. 8 self tapper screws Attach brackets to fence
    6 1 x No. 8 Countersunk screws Alignment screws
    1 5/16 Knob + flat "nut" From Ryobi User kit Attach bracket to back of Front rail
    3 5/16 mudguard washers Spacers for front knob
    2 1⁄4 x 1⁄2 square head bolts From Ryobi User kit Attach bracket to back of Rear rail
    2 1⁄4 knobs & washers Hold the rear bracket
    1 31-1⁄4 TrueFit miter track From woodhaven.com
    Material:
    I used a piece of 1-1⁄4 MDF, laminated on one side, because this is how it came from the counter top store as an offcut. I dont like using anything that is only laminated on one side, but the (very) slight bow was pulled out (and kept straight) by the miter track. Whatever you pick, make sure it will stay flat.
    Overall dimensions:
    Length 37-1⁄4: I wanted the front to extend out as far as the SMT base. This length gives me 15-1⁄2 from the miter fence to the saw blade. The overhang at the back was determined by the width of the bracket.
    Width 7-7/8 : I wanted it wide enough to allow for a T attachment to the rails two bolts at the back, and one at the front. This is 200mm for me and sort of looked right. Maybe it doesnt need to be this wide?
    Thickness 1- 1⁄4 - because this is the size I got from the counter top people! The table height above the rails (on my saw) is almost 1-5/32. I wanted the thickness to be slightly less, so I could use adjusting screws to position precisely. Because of this, you will notice that I had to cut a slight dado above each rail - if you go for around an inch thick, you wont need to do this.
    Slot location: I centered mine put it where you want it.
    Adjustments:
    Height: Two screws above each rail.
    Saw alignment (swing): A screw at each end, on the left hand side of the fence.
    Procedure:
    1. Cut the fence to your dimensions and rout the miter bar/track slot. Cut/ round the corners. Mount the miter track if you use one.
    2. Cut the angle brackets, round the corners, and mark/drill the holes for the mounting screws. The bolt holes come later.
    3. Lay the fence on the rails, hard up against the right hand side of the saw table. Decide on the location (front & rear) and clamp the fence to the rails. On the underside, carefully mark where the brackets will go run a pencil along the rail. At the same time, on the side of the fence, mark where you want the height adjusting screws to go centered above the rails.
    4. Remove the fence and align the brackets with the marks you have made, and carefully mark/drill the screw holes. Then enlarge the screw holes in the brackets by 2 sizes this should give you enough play for adjustment. Drill the holes for the height adjusting screws.
    5. Attach the brackets (not too tightly they will be on and off a few times). Insert the height adjusting screws.
    6. Lay the fence on the rails, and move the auxiliary table up against fence. Adjust the height screws so that you have alignment across the saw table + miter slot + auxiliary fence. Dont worry if you cant get everything perfect I know the tables arent exactly level with each other. In my experience, they are not off enough to pose a practical problem.
    7. Remove the auxiliary table and (lightly) clamp the miter fence to the rails. Now for the only tricky part: Mark the (horizontal) location of the 5/16 bolt on the front bracket. Then mark the (horizontal) location for the two 1⁄4 bolts on the rear bracket. I used a small try square against the rails to help.
    8. Remove the brackets and drill the bolt holes. Because the fence is dropped onto the rails, you need to cut slots in the rear bracket, to slide over the bolts. This is not a problem with the front bracket, because the flat nut slides behind the bracket.
    9. Re-attach the brackets, and test-fit the bolts. If you missed the alignment, enlarge/file the holes until they fit OK. Nothing should jam in fact, you should have a little slop, to allow for final alignment.
    10. Remove the fence and drill the countersunk holes for the two swing alignment screws, on the left hand edge of the fence. I put them 1 in, from each end of the saw table. Insert the screws.
    11. Alignment with the saw: At this point, your brackets should be loose, and the bolts holding the brackets lightly attached. Adjusting the two screws on the edge (and then pressing the fence against the saw table), align the slot with the saw. See the photo for how I did this.
    12. Once youre happy with the alignment, insert the auxiliary table, slide it up against the fence and lock it. Tighten the 3 knobs, making sure that the brackets snug up against the rails. (If they dont, you will have to enlarge the mounting holes in the brackets). Then, from underneath, tighten the 4 screws holding the brackets to the fence. Re-check alignment and run some test cuts to confirm.
    Notes:
    Over the last 7 years, Ive come up with a setup for the BT3K which suits me 99.9% of the time: SMT on the left, rails as far to the right as possible. For this reason, I did not make any allowance for mounting the miter slot on the left of the saw. Mounting it on the right allows (relatively) easy access to the knobs. I also dont believe it needs to move along the rails (normal slots arent movable!). Although its early days, because all the action is fore & aft, I dont think it will need constant adjustment.
    If you need any help, please contact me...
    rodkirby@netspace.net.au
    (admin's note 10/2025, he will not answer, Rod passed away a few years ago, a great loss to those of here on the forum)
    Original PDF Document:
    https://sawdustzone.com/sdz/legacy/MiterSlot.pdf
    Click image for larger version  Name:	MiterSlot0001.jpg Views:	1 Size:	56.8 KB ID:	834497
    Click image for larger version  Name:	MiterSlot0002.jpg Views:	1 Size:	31.6 KB ID:	834508
    Click image for larger version  Name:	MiterSlot0003.jpg Views:	1 Size:	39.3 KB ID:	834498
    Click image for larger version  Name:	MiterSlot0004.jpg Views:	1 Size:	30.3 KB ID:	834499
    Click image for larger version  Name:	MiterSlot0005.jpg Views:	1 Size:	46.1 KB ID:	834500
    Click image for larger version  Name:	MiterSlot0006.jpg Views:	1 Size:	50.3 KB ID:	834501
    Click image for larger version  Name:	MiterSlot0007.jpg Views:	1 Size:	46.6 KB ID:	834502
    Click image for larger version  Name:	MiterSlot0008.jpg Views:	1 Size:	53.0 KB ID:	834503
    Click image for larger version  Name:	MiterSlot0009.jpg Views:	1 Size:	55.5 KB ID:	834504
    Click image for larger version  Name:	MiterSlot0010.jpg Views:	1 Size:	105.2 KB ID:	834505
    Click image for larger version  Name:	MiterSlot0011.jpg Views:	1 Size:	75.2 KB ID:	834506
    Click image for larger version  Name:	MiterSlot0012.jpg Views:	1 Size:	77.1 KB ID:	834507
    Last edited by LCHIEN; 10-08-2025, 02:12 AM. Reason: updated link to PDF file, added note that Rod has passed away
    • MikeT
      MikeT commented
      Thanks for posting the info.
    • othermeans
      othermeans commented
      Thanks just what I was looking for
    Posting comments is disabled.
Latest Articles
    by LCHIEN
    I'm pretty...
    11-30-2025, 02:24 AM
    by LCHIEN
    11-30-2023, 04:00 PM
    12-06-2023, 10:19 PM
    by LCHIEN
    07-09-2023, 01:37 PM
    by LCHIEN
    05-24-2023, 08:55 PM
  • Another Thin Strip Jig
    by twistsol
    In the starting position,...
    04-16-2023, 09:42 AM
    by LCHIEN
    BT3000 tall rip fence
    09-12-2021, 07:58 PM
    10-20-2021, 02:27 AM
The SawdustZone Statistics
Topics: 61,740   Posts: 561,691   Members: 20,829   Active Members: 23
Welcome to our newest member, Mike Hinds.
What's Going On
There are currently 1807 users online. 0 members and 1807 guests.
