Elevation issues
  • ajgoal
    • Feb 2016
    • 6
    Elevation issues
    Over the weekend, I replaced the belts on my BT3000. Saw is running fine with the change. However, now I can't raise or lower the blade. The shims are fine, they were in good shape when I pulled the riser plate off, and they are back where they belong. I removed the blade guard to ensure the pawls weren't catching. I don't believe this is an issue with the threads being stripped, as it will turn about a turn and a half or so in either direction within the same range before binding up. The elevation handle is definitely engaging and turning the drive rod before it catches. I tried disengaging the elevation handle by setting it to adjust the angle and using a wrench to turn the threaded rod, and it binds in about the same location. I've applied dry lube to the screw mechanism, but that had no effect.
    Do I need to pull apart the mechanism? I feel like the elevation wasn't going as high as it should have before this issue, as the blade wouldn't elevate far enough to cut through 1 3/4 inch stock. Is there a possibility that I could just loosen the jam nuts at the bottom and fix the issue? Or am I looking at something more involved? I'm not keen on disassembling the motor elevation mechanism, but if I need to to get the full range of motion out of the saw I will. Does anyone have any hints for the process? I know some folks have fixed the issue, but I am not really sure exactly how they've gone about it.
    Internet Fact Checker
    • 20969
    the first thing to check that you didn't mention, is the elevation rod (vertical threaded rod) and associated parts it conencts to , completely free and clear of sawdust? THat is one of the most common problems I hear when people say their saw elevation is stuck. More suggestions in my BT3 FAQ.
    • ajgoal
      • Feb 2016
      • 6
      Thanks. Turns out that even though I cleaned as much as I could see, there was some still in the teeth on the backside of the gears. Picked up an air gun and blew out the back, and it let the gears rotate far enough that I could use a screwdriver to clean them out completely. Re-lubed everything, and have full range of motion again.
        • 20969
        you're welcome. And welcome to the forum.
        Don't be a stranger.
        Like I said, my BT3 FAQ might be an interesting read. See my sig line below.
        • tfischer
          • 2343
          Welcome to the forum - hope you stick around.
          • ajgoal
            • Feb 2016
            • 6
            Thanks guys. First thing I did when I signed up was to get a copy o the FAQ. Been really informative.
