Help! 2.5" (ssd) to 3.5" drive brackets.
    • 4889
    Ordered my first SSD, along with the new motherboard, memory and such (should be here tomorrow), and realized, since I am using an older case, its smallest spot is 3.5".
    I didn't think to order the bracket, and still have an older 3.5" to 5.25" adapter bracket set. Has anyone used them for 2.5" instead? (rather not strip the holes if it won't work) Pictures online in some cases, show the same brackets, but pictures are not always updated, so I am asking for hands on experiences.
    Thanks
  • Stytooner
    Roll Tide RIP Lee
    • 4301
    • Robertsdale, AL, USA.
    My 60 GB SSD from Corsair came with it's own 3.5" mounting plate. I use it for cache only.
    The 120 GB I use for the main drive did not, however if it is in a desk top, I don't think it will slow you down.
    There isn't any moving parts, so won't hurt anything to run unmounted for a few days until a proper mounting plate does arrive.
      Internet Fact Checker
      • 20982
      i'm pretty sure its not the same bracket as 5.25 to 3.5 - the drive is physically much smaller.
      Duct tape can be your friend. The 2.5 SSD are small, light and have zero moving parts.
        • 9231
        Did you get a retail box drive, or a bare drive for that SSD? If it is a retail box it should come with the adapters...
          • 9231
          Uh, no they are not the same, and EEK! Duct tape?! Please say it isn't so!
          • JSUPreston
            • 1189
            • Montgomery, AL.
            In a pinch, I've mounted a 2.5 SSD in a 3.5 bay by just attaching it on one side. As others have said, no moving parts, so it should be safe until you get a proper bracket.
            I've seen 3.5 drives mounted in 5.25 bays by folks using long screws and spacers/washers.
            • Condoman44
              • Nov 2013
              • 178
              • CT near Norwich
              A pinch? I am finally doing a rebuild of my XP desktop to Win7 x64. The 1tb drive I put in a couple years back has never had a slot, it's standing on end just inside the case.
              The new config will fix that.
              BTW, new MSI board out for repair as it was DOA.
              • JSUPreston
                • 1189
                • Montgomery, AL.
                I've done that before as well, but with 2 dogs, 3 cats, and 2 boys, I doubt that I could get away with that again.
                • jdon
                  • Feb 2010
                  • 401
                  • Snoqualmie, Wash.
                  C'mon, you're a woodworker- surely there's something in your scrap bin you can use to craft a one-off mount!
                  • radhak
                    • 3061
                    • Miramar, FL
                    • Right Tilt 3HP Unisaw
                    Don't jerry-rig anything. A mount for it costs negligible, but gives a lot of peace of mind. I have this and it works great for the past few years:
                    - Aristotle
                      • 4889
                      When SATA first came out, new drives all had the cable with them. After a tipping point, they didn't. SSD's have become that way (they don't all come with brackets).
                      I did wonder about wood, but wasn't sure of any grounding issues. Started looking online for a template (eventually found one), because I haven't opened the old case yet, to see if I can remove the 3.5" section, or if it is riveted (old ATX case that was last used for a Pentium 133).
                      Something hit me though, today; I left the old floppy in it, just to have no openings and realized I should be able to use it for my bracket, since I found the template.
                      One 5.25 adapter bracket, would screw on, in one hole, and would make it close to 3.5", but not quite.
                      Another option that I wondered about, was zip ties.
