Results 1 to 9 of 9
Thread: Doh! How do I remove cooking oil from concrete pavers?
  1. #1
    Join Date
    Aug 2003
    Location
    Maryland, USA.
    Posts
    3,114
    My trash bag sprung a leak from the kitchen to the trashcan outside. There's a streak of cooking oil on my concrete pavers now. How do I get rid of it? Dishwashing soap? The oil has already soaked in. I'm not talking drips. I'm talking streaks.
  2. #2
    Join Date
    Dec 2004
    Location
    Rochester, NY.
    Posts
    3,810
    I'd think that a degreasing soap followed with a methanol rinse might help, but if it has sunk into the surface you might try plaster of paris. Mix plaster of paris with water to a paste. To each cup of the mixture you make, add one teaspoon of degreasing dishwashing liquid and mix. Apply the plaster of paris over the stains, allow it to dry completely, and then sweep it away. It should suck the oil of the concrete.
  3. #3
    Join Date
    Feb 2005
    Location
    Cypress, CA, USA.
    Posts
    701
    I've used spray brake cleaner (from any auto parts store) to clean fresh oil drips/spills on the concrete driveway. As long as the oil is less than a few days old this seems to get the stain out. Tide laundry detergent works pretty well too on oil/grease. Make a slurry, slop it onto the stain, and let it soak/absorb the oil.
    good luck.
    mpc
  4. #4
    Cooking oil is a different deal than automotive oil. I have cleaned cooking oil off concrete with a solution of lye water.
  5. #5
    When workers clean up after large crude oil spills, they use Dawn dishwashing liquid. I don't know how well this will work on porous paver tiles but if you let it soak in it might bring everything back up.
  6. #6
    I would try a concrete absorber/degreaser. The BORG has one that you pour one in a liquid form and wait for it to dry. You then sweep it up. It's worked well for me.
  7. #7
    Join Date
    Nov 2006
    Location
    Chandler (Phx), AZ
    Posts
    1,741
    spread oil on the others too make a pattern. it'll be easier
    omar
  8. #8
    Join Date
    Oct 2008
    Location
    Spokane Washington
    Posts
    456
    I found this on fine woodworking this morning. You might just try some saw dust and let it sit for an hour or two.
    http://www.finewoodworking.com/item/...gulf-oil-spill
    Art
  9. #9
    Join Date
    Apr 2008
    Location
    League City, Texas
    Posts
    7,411
    Dawn takes grease out of your way...
    Seriously. I had a similar thing happen on my sidewalk on trash day. (can had a leak it appears...). Dawn, a garden hose, and a stiff bristle broom to scrub with...
    My personal workshop blog is http://daves-workshop.blogspot.com. My camping / hunting / outdoor blog is http://wildersport-outdoors.blogspot.com/
Thread Information
Users Browsing this Thread
There are currently 1 users browsing this thread. (0 members and 1 guests)
Bookmarks
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
