DIY tree stump removal, drill bit getting caught?
    • 5633
    A stump grinder is a very manly tool!
    Pretty funny about the burning thing, though. It's just not something that would be discussed here. Between air quality concerns and fire danger, homeowners with kerosene and a match will cause a riot.
      • 9209
      Okay you guys have me intrigued by the burn out method...
      How can I be sure this is a SAFE thing to do?
      I am concerned about the roots burning underground and catching something else on fire.
      My thought process as I understand what you guys are saying is this...
      #1, clear off any and all combustible materials within a reasonable radius to the stump. In the case of the Beech, I have about 4 feet before the fence, some leaves, etc that can be raked away etc...
      #2. Fill the holes that I already have in there (This was a TON of work) with some sort of liquid fuel. I have LOTS old Coleman fuel left over from last season... Let it soak in.
      #3. form a basket of sorts around the stump with hardware cloth and fill that basket with charcoal. (Not going to cook on it, so cheapo Wally World charcoal should be okay right?)
      #4. Set lawn chair on deck, with cooler, and hose next to the chair (just in case) apply means to start charcoal (I usually use a charcoal chimney and newspaper).
      #5. Start fire and observe as it burns the stump out....
      Any idea how long I will be sitting there making sure this doesn't become Mrs. O'learys Cow?
        • 9209
        Stump grinder is not an option for my back yard. Every stump grinder I have looked at is 36" wide, my gate is 32", and the city gives BIG tickets for driving down the Bayou... (I thought about towing one behind the house down the Bayou but don't want to risk a $500.00 ticket).
          • 5633
          4a. Pop the top on a carbonated yeast-based beverage (CYB-squared)
          4b. Shout, "Honey! Watch this!"
            • 9209
            Uh, I MAY live in the south, drive a pickup, own firearms, etc...
            But I have NEVER uttered the phrase (at least non jokingly...) "hold my beer and watch this!"
              Comments below...
              I've burned out 4 stumps so far including two pines that had been dead for along time and no roots caught fire underground
              Yes. I also dig a trench of sorts and keep it wet.
              Helps especially on green wood but not necessary. The difference is if you don't do this you use a little more charcoal. If you do this, then the burning smells like the fuel. I am far enough away from my neighbors that nobody cares. If all you use is charcoal then all it smells like is a grill. I use diesel. You DON'T want gasoline. Too combustible. Something heavier like diesel or kerosene.
              Yes.
              Depends on how big/close to the ground/dry the stump is. I had a dry pine stump burn in a few hours. I had a green oak stump that took two burnings and the second one one smoldered overnight. I wouldn't start a fire then go away for the day, but I have started it up, let it go and did other outside stuff with just coming back to check every half hour or so. Oh and especially on green wood you can rake the charcoal off and the stump will extinguish itself if you need to go away. This is better than wetting it cause then you have to wait for it to dry to start the burn again.
              • sscherin
                • 772
                • Kennewick, WA, USA.
                I have a 3' diameter stump in the back yard.. Think I'll need 2 or 3 bags of charcoal?
                The PO tried to grind em out but left 2-3" above grade
                William's Law--
                • rnelson0
                  • Feb 2008
                  • 424
                  • Midlothian, VA (Richmond)
                  • Firestorm FS2500TS
                  #23
                  Lowest quote I got for stump removal for all 5 is $750.00 so DIY is worth the effort...
                  I thought stump removal was expensive as well. I found a retired guy here who ground a stump for me for $45. Considering it was a huge 2' diameter stump with all the gnarled roots everywhere and I wanted to actually plant on top of the roots, that was far more effective than any DIY effort.
                  I would check around for some retirees at the bowling lane or something who do it for beer money, not a living anymore.
                    • 15218
                    It would depend on what size bag you buy. I buy the 24 LB bags and would guess you could get by with 2. It might depend on how wet, tree type and overall size.
                      Probably 3. At least. The other reason to burn them out is, its fun. Plus I've heard of guys grilling dinner over the coals (although I wouldn't if you add fluids to help the fire along).
                      • Hellrazor
                        • 2091
                        • Abyss, PA
                        • Ridgid R4512
                        #26
                        What? Don't tell my neighbor that... He loads up his charcoal with so much lighter fluid the flames are 2' high and throws his steaks on the grill while the flames are still visible and it smells like burning lighter fluid. yuck..
                          • 9209
                          Well, I got home, and applied the drill with a more gentle touch, clearing the bore FREQUENTLY using the Speed Bor Max bits. I took a different tack this time by starting the holes with th e5/8" bit, then 7/8" and finally 1". So Stump Out is in them, it's too stinking hot here to be in a hurry anyway, so I wait. 6 more weeks puts us in October, which is fine, it will be cooler then... I have some time to clear the bits of remaining fence that one of these trees was pushing over, and strip out any other remaining problem landscaping so I can maximize my trip to the dump...
                          After looking into what surrounds these stumps, as soon as it is all clear and my 6 weeks have gone by, I am going to do the charcoal trick to them. Probably start early on a Saturday morning...
                          Then the fun begins once that is all done. Putting the fence back in... I'm renting a gas powered auger to dig the new post holes for sure!
                          • Bill Stock
                            • 186
                            • Canada, Eh!
                            A little late to this thread, but I had a similar problem with a fresh stump in the spring. It took a lot of hole clearing as you indicated. I put a pound of KNO3 in the holes and covered it with peat moss. I'll have to look at it again and add my other pound of 'stump remover'. I've heard of people drilling holes and poring some kind of flammable stump remover in the holes; mostly kerosene I think.
                            My favourite method is to winch them out when possible, although at 12" it takes a lot of digging first. The worst was a double 12" stump I had to dig out for a shed. I've got a 6" to do in a couple of weeks, but I'm hoping it will pull right out of the ground.
                              • 15218
                              Nothing better than immediate results. Mozey down to your local Ace Hardware and pick up some C4 (they must have a homeowners version).
                              • WayneJ
                                • 785
                                #30
                                I knew somebody would think of that. C-4 will make that stump disappear. Its also good for fishing.
                                Wayne
                                Wayne J
