Page 1 of 2 12 LastLast
Results 1 to 10 of 17
Thread: Delta 50-760
  1. #1
    Join Date
    Nov 2003
    Location
    Holly Springs, NC
    Posts
    371
    Delta 50-760
    I recently bought the DELTA 50-760 and I have put it together, but I have a quick question to anyone who has this dust collector. How did you put on the lower bag? Did you use the band clamp or did you use the felt ring? I used the felt ring but was unable to following the directions exactly. I tried rolling the bag over the ring and snapping it in like the top bag with no success, the bag would slip and some other issue would arise. I finally took the top bag off, slid the bag up from the bottom so the bag extended about 4 to 5 inches into the hole then took the felt ring and dropped it in from the top got one side in then while smoothing the bag I snapped it in place. Does anyone know the secret to this; because I also noticed it doesn't seem to want to snap out with the hugging technique. In order to remove the lower bag it seems that I need to remove the top bag first so I can reach inside and pull the ring out.
    I love lamp.
  2. #2
    Join Date
    Nov 2004
    Location
    Moncks Corner, SC, USA.
    Posts
    790
    It took me a couple of times to get the hang of it but I'm able to take it off and put it on from the bottom. I just loosely wrap the bag over the felt insert and pust in from one side till I get it lined up and it pretty much seats itself. That was the main reason I went with a trash can seperator by the way. I haven't had to empty mine in several months.
  3. #3
    Join Date
    Nov 2003
    Location
    Holly Springs, NC
    Posts
    371
    Another quick question about the trash can seperator. I bought Woodstock W1049 Large Dust Collection Separator (http://www.amazon.com/gp/product/B00..._ya_oh_product) and a 30 gallon trash can. My trash can is 27" tall and once I pit on the lid I cannot slide the can on the base with the y adaptor comming out of the motor area. How did you set up your seperator? Do I need to try to find a shorter can, or should I try another lid.
    I am trying yo find an adaptor that would fit on the 5" opening and change it to a 4" for a 4" hose but all the reducers I find are for the hose to go on the outside. Even without the adabptor there barely looks like there is enough room for the hose to come out and then turn into this lid.
    I love lamp.
  4. #4
    I have the 50-760 and love it. I have never had a real problem getting the bags on/off although I do take the top bag off when I empty the bottom as it always seems timely to do a general clean.
    Dont mean to hi-jack this thread but I wondered what other 50-760 or other DC owners do about cleaning the filter bag. I do give mine a good shake once I have been using it and all sorts of debris drops into the bottom bag but I did wonder about the pros/cons of a good clean.
    I have always understood that a "conditioning" of the bag with a layer of dust helps with the filtration but at what point is it too much and prevents good airflow. I have thought about blowing some compressed air through the bag and even taking it off and washing it.
    Any experiences or thoughts on this topic?
    Join Date
    Apr 2006
    Location
    The Great Land - Alaska
    Posts
    1,001
    A timely thread indeed . . . . .
    I am considering upgrading from ShopVac dust collection to a real dust collector and have been looking at the Jet DC-650 (with Canister) and the Deltas. I like what I am reading about the 50-760, but would like to use a canister instead of a bag. Does anyone know if the Delta 50-760 can be fitted with a canister?
    Thanks and regards, Steve
  6. #6
    Join Date
    Nov 2004
    Location
    Posts
    790
    A friend just got the Wynn cannister but the jury is still out whether he will like it better or not.
    http://www.wynnenv.com/delta_50-760.htm
  7. #7
    Join Date
    Apr 2006
    Location
    Posts
    1,001
    Mike,
    Thanks for the information about fitting a Wynn canister to the Delta. While I am reasonably confident that the Delta 1 micron bag would work OK for me, I want to avoid, or at least minimize, dealing with removing and cleaning the bag from time to time (severe allergy problems). The half-micron specs for the Wynn is additional encouraging news.
    Regards, Steve
  8. #8
    Join Date
    Apr 2008
    Location
    League City, Texas
    Posts
    7,410
    Yes, the Delta 50-760 can be fitted with a Wynn 35A.
    HOWTO Installation Writeup.
    The 35A product page is linked below...
    http://www.wynnenv.com/35A_series_cartridge_kit.htm
    If I had the budget I would have gotten a 50-760 with a 35A, but it wasn't in the cards for me...
    I wish I could find the post, but there is somebody on Phil Thien's forum that stuffed a 30 gallon trash can separator under the intake on his 50-760. But it is CLOSE...
    I would say return the factory built separator lid and 30 gallon can, get a 20 gallon galvanized can and build a Thien cyclone for it...
    Not sure if the separator baffle would work in the inlet ring of a 50-760 though...
    My personal workshop blog is http://daves-workshop.blogspot.com. My camping / hunting / outdoor blog is http://wildersport-outdoors.blogspot.com/
  9. #9
    Join Date
    Mar 2009
    Location
    westchester cnty, ny
    Posts
    1,142
    is this the one you are referring to:
    http://www.cgallery.com/smf/index.php?topic=132.0
    skip down a few posts for photos of the drum under the dust collector.
  10. #10
    Join Date
    Apr 2008
    Location
    League City, Texas
    Posts
    7,410
    Awfully close, but not exactly. The one I was talking about used a galvanized trash can... But honestly the steel barrel is better...
    I like the coupling he used, but would think thumb screws would be easier to use...
    I think a quick trip to a friend with a welder and a penchant for metal fabrication would get that cross brace fixed right too...
    FWIW, I got an email from Rockler a couple of days ago, that is for a plan to mod a regular DC to put the impeller motor in the same orientation as a 50 760... I may just have to build one for my HF DC...
Thread Information
Users Browsing this Thread
There are currently 1 users browsing this thread. (0 members and 1 guests)
Bookmarks
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
