Page 1 of 2 12 LastLast
Results 1 to 10 of 12
Thread: Cutting 4" Cast Iron Sewer Pipe
  1. #1
    Can any one recommend, through real experience, a SawZall Blade for cutting Cast Iron 4 Sewer Pipe?
    Tungsten Carbide Grit or Bi-Metal Blade? Any blade/Manufacture would be greatly recommended, including tips
    Thanks,
    Join Date
    Aug 2006
    Location
    Englewood, CO
    Posts
    63
    I used a 4" grinder with a metal-grinding disc in it to cut a score around the pipe about 1/8" deep and as narrow as possible. Then take a masonry chisel (not a woodworking chisel) and place the tip in the score and hit it sharply with a hammer. The pipe should break cleanly along the score line. There is a tool that breaks cast iron pipe in one easy step...I'm not sure what it's called (a "pipe breaker?") but it's probably not worth buying or renting one if you're only making a few cuts.
    Mark
  3. #3
    Join Date
    May 2005
    Location
    Paso Robles, Calif, USA.
    Posts
    2,879
    I think a good bi-metal blade will handle it. cast iron is not terribly difficult to cut. I've used milwaukee and lennox blades with good results. milwaukee lists their general purpose blades for cutting cast iron.
    if it has a layer of heavy rust you'll need to clean the rust off where you are starting the cut. rust can be so hard/abrasive that it will dull the teeth before you start.
    I like mrojec's idea better though.
  4. #4
    Join Date
    Jan 2003
    Location
    Mebane, NC, USA.
    Posts
    10,624
    From real experience I would go with the angle grinder. Most recently I had to remove some cast iron from my fireplace last year and sawzall would not touch the stuff even after starting it with the angle grinder. Score as neatly as you can with the angle grinder then break with a cold chisel. I w You can get thin cutting blades ~ 1/8" thick at the home centers. Buy several.
    Watch the sparks - there will be many. I use a full-face shield for jobs like this. Move the tool in the opposite direction the blade is spinning - same concept as using a router. You will get better control. If you move it the wrong way it will still cut but will want to skip a lot more.
  5. #5
    Join Date
    Jan 2003
    Location
    Cedarburg, Wi, USA.
    Posts
    103
    Because of all the sand in it, sewer pipe will go through blades fast. A sawzall is pretty much useless on it. The grinder works but takes a while, and forget it if the pipe is up in the floor joists. A good rental center should have the snapper tool, 1-2 minutes per cut compared to 1/2 hr - hour or more.
    M. Leichtle
    Beer is proof that God exsists and wants us to be happy.
    Ben Franklin
  6. #6
    Join Date
    Jan 2004
    Location
    Copiague, New York, USA.
    Posts
    1,170
    I cut my 4" cast pipe w/ a sawsall, I went to HD & bought a 6" or 8" carbide blade. It took a while, & my hands were tingling from the vibration, but it did the job. There is a tool that does this, it is sort of like a chain type cutter that ratchets, I don't remember what it's called but you can google "cutting cast iron pipe & it probably will come up. Good Luck, Joe
    It's got to be us, because there are a lot more of them!
  7. #7
    Join Date
    Dec 2005
    Location
    Gilbertsville PA
    Posts
    259
    I would try the rental also. I have only seen them on TV but the chain cutter ( I think it really snaps the pipe) will make short work of it. This must be a vent pipe. I think the biggest worry is support for the pipe after the cut.
    Thanks again,
    Join Date
    Feb 2005
    Location
    Independence, MO, USA.
    Posts
    4,783
    Quote Originally Posted by Perfidiajoe View Post
    Soil pipe cutter. Might call the rental place to see what it will run.
  9. #9
    Lightbulb
    Thanks for all the replies and I will keep you updated.
    The 4 Sewer Pipe in question is under the basement concrete floor. Its my sons house who is 23 years old. He has two Plummer friends one his age who is helping. The other is a coworker @ the Electrical/Mechanical Engineer Design Company.
    His young plumbing friend does not like to use the Pipe Snapper in this application, fearing it might break somewhere else under the basement slab. He prefers to just use an angle grinder to completely cut through the cast iron pipe.
    His older coworker friend handled him a pipe snapper and told to have at it, since his house is not that old (Built 1972).
    I sent an email to Lenox & Milwaukee hoping for a response on what type of Sawzall blade to use.
    My son is leaning towards using the Pipe Snapper Tool.
    Thanks Again
  10. #10
    Join Date
    Jan 2003
    Location
    Mebane, NC, USA.
    Posts
    10,624
    I'd ask the older friend if he'd still use the pipe snapper if it were his house. Then I'd listen to the younger friend and go get my angle grinder. The extra time it will take with the grinder is a LOT less time and cost it would take to find out there was a leak under the slab and have to excavate and repair it.
    Good luck.
Thread Information
Users Browsing this Thread
There are currently 1 users browsing this thread. (0 members and 1 guests)
Bookmarks
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
