Page 1 of 3 123 LastLast
Results 1 to 10 of 29
Thread: Air Wrench / Impact Driver for Lawn Mower Blade Removal?
  1. #1
    Join Date
    Apr 2005
    Location
    Mountain Lakes, New Jersey, USA.
    Posts
    314
    I am looking for some advice on selecting a tool to make it easy to remove a lawn mover blade. As I have gotten older, my strength is not what it used to be and I struggle remove the blade when the bolt is put on too tight.
    I recently purchased a 1/4" Milwaulkee Impact driver which is just great for driving screws & bolts. Big imporvement over a cordless drill. I like the torque this tool provides, but I am not sure how well it will work for removing the lawn mower blade.
    I am wondering if an air wrench like this would be a better tool.
    http://www.harborfreight.com/cpi/cta...emnumber=47214
    I like the shape of this tool for getting under the lawn mover without having to turn the mover on its side. Will an air wrench like this provide sufficent torque to remove the bolt? I have never used an air wrench.
    Or do I really need an air powered torque wrench - somethng like this?
    http://www.harborfreight.com/cpi/cta...emnumber=53176
    What do you use / what would you recommend?
  2. #2
    Join Date
    Feb 2005
    Location
    Golconda, Illinois, USA.
    Posts
    16
    Wink
    My advise. Look around find a impact tool 1/2" or larger
    that has 600ft lbs of torque. This would probably be able
    to take lug nut off a car also. The little torque wrench
    has only 50-60 ftlbs of torque. I use mine the same way
    you want(lawn mower blades etc..).
  3. #3
    Join Date
    Jun 2004
    Location
    West Central Ohio
    Posts
    1,912
    Save your money!!! Use the impact driver you already have. Check out the spec's, I'll be willing to bet it has more than enough torque to do the job. It might even have enough to torque the head off the bolt. At the very least try it first!!!
  4. #4
    Join Date
    Dec 2002
    Location
    Katy, TX, USA.
    Posts
    17,170
    the air wrench will just end up spinning the blade and motor around.
    You need an impact tool or you will have to supply the manual counter-torque to the blade and motor.
    The impact tools will pop the bolt with short rapid bursts of energy that will let the inertia of the blade and motor keep it from turning.
    I don't think the bolts on the lawnmower are that big (can use with 3/8" socket sets), probably your electric impact driver will work if you have socket adapters for it. Try it anyway.
    I don't think you need to torque the bolt excessively when putting it back on, it has a hub that engages the blade to keep it from spinning and the bolt should have a lock washer IIRC (been a while - I have someone doing my lawn now).
    PM me (with your e-mail address) for a copy of the BT3 FAQ current vers 4.13
  5. #5
    my craftsman air rachet works great for stuff like that. It still turns in tiny increments like an impact gun so stuff that normally requires brute force to hold still (like a lawnmower blade) when you use a wrench you dont any more. So almost any time I need to remove a bolt like that thats what I grab. Wheels on a grinder is another one its great for.
  6. #6
    Join Date
    Feb 2005
    Location
    Independence, MO, USA.
    Posts
    4,783
    Is the problem the typical one, where the blade wants to turn why you are trying to loosen the bolt?
    If so, just go to Lowes.com and search Item # 188341
    Model # BB-100 blade buster. I use that and a either a breaker bar, or one of my 1/2" flex head ratchets. Since they saw me using it at the garage, I always get asked if it can be borrowed.
    Not sure if this will take directly to it if Lowes allows:
    http://www.lowes.com/lowes/lkn?actio...100&lpage=none
    Air ratchets, typically still need the bolt broke loose, and if you have to turn it over enough for an impact wrench, you might as well turn it over.
  7. #7
    Join Date
    May 2005
    Location
    Paso Robles, Calif, USA.
    Posts
    2,879
    as has already been mentioned; I'd give your cordless a try, they can be amazingly strong. air rachets have very little torque.
  8. #8
    Along with many other tools I have a 3/8" dr Blue Point air ratchet. Blue Point is a Snap-On value brand. For breaking fasteners loose it is next to worthless if any torque is needed, the same is true of tightening. To remove my John Deere's blades I use ] this ratchet 15" 1/2" dr which gives me plenty of leverage. Before I replace the blade bolts I coat them with anti-sieze which seems to keep them from becoming too hard to remove.
    marK in WA and Ryobi Fanatic Association State President
    Join Date
    Apr 2005
    Location
    Posts
    314
    Quote Originally Posted by TheRic View Post
    I checked the specs and I was surprized to learn that my little Milwaulkee 1/4" Impact Driver has a Torque rating of 740 in.-lbs. I thought the tool would be unsized / underpowered for the job, but I going to give it a try before I do anything else.
    Thanks to everyone for their ideas and suggestions.
  10. #10
    Join Date
    Jan 2003
    Location
    Mebane, NC, USA.
    Posts
    10,624
    In the past I've had problems with powered tools torqueing the heads or rounding off bolts/screws etc. I prefer to back out stuck bolts the old-fashioned way - a longer handle on my wrenches. that way I can feel if it is not moving like it should.
Thread Information
Users Browsing this Thread
There are currently 1 users browsing this thread. (0 members and 1 guests)
Bookmarks
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
