Results 1 to 7 of 7
Thread: Router Speed Control on grinder
  1. #1
    Join Date
    Nov 2003
    Location
    Lago Vista, TX.
    Posts
    471
    I have the small Ryobi bench grinder and am wondering if a router speed control could be used to slow it down. Thinking about getting a grinding wheel more suitable for sharpening tools.
    TIA
    Ken
  2. #2
    Join Date
    Dec 2002
    Location
    Katy, TX, USA.
    Posts
    17,170
    Quote Originally Posted by lago
    TIA
    Ken
    Most all of those grinders use induction motors.
    If the speed is 3400 (most likely) or 1700 RPM (less likely) or thereabouts, it's an induction motor.
    Can't use a router speed controller with induction motor, no, no, no!
    PM me (with your e-mail address) for a copy of the BT3 FAQ current vers 4.13
  3. #3
    SARGE..g-47 Guest
    You can still use the higher speed to sharpen. The three major problems with a 6" high speed IMO are:
    (1) the six inch wheel is more prone to leaving a hollow grind because of the sharper arc...
    (2) Most come with the harder grey and courser grit wheels. The white wheel is softer and will tend not to heat up the metal as quickly...
    (3) The faster speed will heat you metal quickly and if you stay at the wheel, it will cause your steel to lose temper and you're looking at folded and chipped tips from that point forward.
    A solution if you don't want to down-size to a lower and more expensive motor is to slow it down. Touch the metal often and before it gets too hot to keep your finger on it, lie it down and let it cool. When it has, you can come back to it to proceed.
    Not a lot you can do about the hollow grind. I don't use the wheel for my hand plane irons or better chisels other than to take a deep nick off the tip. I used to use water stones, but find myself with paper in various grits on a tempered piece of glass. Once you have flattend backs and set the primary angle when you get the tool, touching up is really a snap.
    Evening...
  4. #4
    Join Date
    Nov 2003
    Location
    Lago Vista, TX.
    Posts
    471
    Thanks for your input as that anwsers my question. I knew there was a difference in electrical motors but wasn't sure if a speed control could be used on one.
    Ken
  5. #5
    Join Date
    Apr 2005
    Location
    Mountain Lakes, New Jersey, USA.
    Posts
    314
    Is there a practical way to reduce the speed of an induction motor?
  6. #6
    Join Date
    Dec 2002
    Location
    Katy, TX, USA.
    Posts
    17,170
    Quote Originally Posted by Uncle Hook
    Run it on a lower frequency like 50 Hz...
    They make AC frequency controllers that provide sinewave power at different frequencies for variable speed work. There's a limited range over whcih they will work.
    Grinders have direct drive so changing pulleys or gears is out.
  7. #7
    Join Date
    May 2004
    Location
    Off The Back
    Posts
    6,685
    Quote Originally Posted by LCHIEN
    Usually, yes. But this is one of the big advantages of mandrel-style grinders: you can gear the suckers up or down, make 'em run at whatever speed you want. They do take more room, but IMO the ability to change speeds is well worth it. At the moment I have free use of a regular bench grinder but when I get one of my own, I'm going to go with a mandrel style (may even build it myself).
Thread Information
Users Browsing this Thread
There are currently 1 users browsing this thread. (0 members and 1 guests)
Bookmarks
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
