Page 1 of 2 12 LastLast
Results 1 to 10 of 13
Thread: Routing a 2" Deep Mortise?
  1. #1
    Join Date
    Nov 2005
    Location
    Sylvania, OH, USA.
    Posts
    1,372
    Question Routing a 2" Deep Mortise?
    I need to rout a mortise that is 2" deep. The max I can go with my 690 and spiral bit is 1". I did a search and saw some bits in the $80-$100 range that might reach, but I am not going to pay that much.
    Any suggestions before I use the DP and a chisel (ugh) to finish the remaining 1"?
  2. #2
    Yeah, there are straight bits that will go down to 3", but they are pricey. 2" deep eh, pretty big tenon going into that. You could rip the stock to 2" wide, route from either side, then glue the falloff back on.
  3. #3
    Mortise depth is a real problem with a router. That is why I am looking at buying a seperate mortiser. I hate to spend the money but over the long run I think that it would be worth it. Looking at the Woodtec 1HP.
    I know that this is no help but just wanted you to know that you are not alone.
    Allen
  4. #4
    Join Date
    Dec 2002
    Location
    Katy, TX, USA.
    Posts
    17,114
    Quote Originally Posted by allen
    Allen
    Yeah, most mortisers cut to about 4" max, a real advantage.
    PM me (with your e-mail address) for a copy of the BT3 FAQ current vers 4.13
  5. #5
    HF has a stand-alone mortiser that goes on sale from time to time at $99. If you've got a 20% off coupon, then it's $79. It's good enough for most non-pro jobs. There are also add-on mortiser kits for some drill presses, but most cost more than the HF stand-alone.
  6. #6
    Join Date
    Feb 2006
    Location
    Edmonton, AB
    Posts
    1,079
    If you go buy a 1/2" end mill (for steel) of the 4 flute variety, I think you'll get very close to your 2" depth. Any supply store that sells to machine shops should have them for around $30-40.
    Be VERY careful!!! Big & Sharp!!
    Brian
    Welcome to the school of life
  7. #7
    Join Date
    May 2004
    Location
    Off The Back
    Posts
    6,685
    How wide is your mortise? Whiteside, CMT, and probably others make straight bits with 2" long cutters and about a 3-1/2" overall length, for like ~$20-22. The catch is that I think they're 1/2" diameter and up.
    Join Date
    Oct 2005
    Location
    Coeur D\'Alene, Idaho.
    Posts
    321
    You could get the rest of the depth with a forstner bit at the drill press.
  9. #9
    Join Date
    Jan 2003
    Location
    Stevens, PA, USA.
    Posts
    1,785
    Am I the only one that would rip the piece in half and use a dado set and then glue-up??? (I guess I'm assuming this is a through-mortise, altho' I can't see any other reason that it would need to be 2" deep)
    I don't have a mortiser, but a 2" mortise sounds killer to me. I don't have a router bit that long either nor am I sure I'd want to use one if I did, at least for mortising anyway. (call me paranoid).
    Maybe I'm just
    or off my rocker
  10. #10
    It's no doubt a monster of a mortise. If it were a through mortise, it could be done by going 1" down from each direction, referencing from the same face. I agree though that a 2" mortise would be mighty scary.
    I have a project in my future where I'll be doing a 3" deep dado with a router, 1.5" from either side, that'll be plenty scary enough for me, thanks.
Thread Information
Users Browsing this Thread
There are currently 1 users browsing this thread. (0 members and 1 guests)
Bookmarks
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
